Inleiding
This guide will walk through the steps to replacing the frame and hinge on a HP Compaq nx7400 laptop.
Wat je nodig hebt
Here you can see where the hinge broke.
Remove the screw shown, and set it aside you will need it later for re assembly.
This screw is normally hidden under the rubber pad above it.
Carefully pry up the panel with the power button to locate this screw. It is under the raised portion connecting the screen with the rest of the laptop.
This was the hardest screw to remove because the panel is difficult to pull up. I pulled it up just enough to get my screw driver in there.
The screw goes through the cable in the picture, make sure to keep it in there when you put the new hinge in.
6 andere personen hebben deze handleiding voltooid.
4Gids Commentaar
Here it is mentioned that you need a T10 torx screw driver. But that is not right. I bought a T10 and found that is too large. Later I found in the HP repair manual available at http://www.manualslib.com/download/27316..., that the screw size is T8 Torx.
I had to replace both the hinges and had a donor laptop. this is how i found out that if you take off the top bezel(where the switches live) near the screen by removing three wide black screws under the battery, you don't have to pry open the two halves to reach the top screw on the hinge. for easier removal of the top bezel i removed the keyboard also by loosening the screws on the underside and unhooking the four clips which can be found between the keys. this manual was still a great help to get me started and familiarize myself with the different components.
Hello there,
My HP Compaq 7400's screen casing is broken along with the hinges and I literally have to make it lean on something like a wall.
I'm looking for the whole thing. Can you help me?
Thanks in advance.
