Ga door naar hoofdinhoud
HP Compaq nc8430 Battery Replacement
  1. HP Compaq nc8430 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Completely shut down the device and unplug any adapters and cords connected to the device.
    • Carefully flip the device over so that the bottom is facing up.
    • Slide both of the latches to the left.
  2. HP Compaq nc8430 Battery Replacement: stap 2, afbeelding 1 van 1
    • Slide up against the three lines the battery has.
  3. HP Compaq nc8430 Battery Replacement: stap 3, afbeelding 1 van 1
    • Slide the battery up and away from the laptop.
    • Slowly remove the battery to prevent any connectors from getting damaged.
Conclusie
Karen Gandara
101 Reputatie
1 Handleiding geschreven
Texas Tech, Team S13-G4, Bennett Spring 2017 Lid van Texas Tech, Team S13-G4, Bennett Spring 2017
TTU-BENNETT-S17S13G4
5 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 13
Altijd: 708
