Ga door naar hoofdinhoud
HP Compaq Presario V6000 Wifi antenna card Replacement
Wat je nodig hebt
  1. HP Compaq Presario V6000 Wifi antenna card Replacement, Wifi antenna card: stap 1, afbeelding 1 van 1
    • Grab a Type-Cross #1 screwdriver and unscrew the 3 screws and take off the cover of the wifi antenna card.
  2. HP Compaq Presario V6000 Wifi antenna card Replacement: stap 2, afbeelding 1 van 1
    • Use your finger tips to pry off the gray antenna connections.
    • Be careful to not pull the antenna wire too hard, you may cause damage to the connection permanently and/or motherboard.
    • The screwdriver is only being use to demonstrate which wire to remove. The screwdriver can potentially damage the motherboard if used improperly.
  3. HP Compaq Presario V6000 Wifi antenna card Replacement: stap 3, afbeelding 1 van 1
    • After removing the connection cable, remove the two screws that hold the wireless card to the motherboard.
    • Then gently remove card without causing any damage to card itself or surrounding parts.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Hunter Griffin
104 Reputatie
1 Handleiding geschreven
Texas Tech, Team 38-4, Bennett Fall 2016 Lid van Texas Tech, Team 38-4, Bennett Fall 2016
TTU-BENNETT-F16S38G4
4 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 730
