Ga door naar hoofdinhoud
HP Compaq Presario V5303NR Battery Replacement
  1. HP Compaq Presario V5303NR Battery Replacement, Battery: stap 1, afbeelding 1 van 2 HP Compaq Presario V5303NR Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • A switch is located below the battery, take your finger and push it over to the left.
    • The instruction to push the latch to the left is only relevant to the first image. The second image, which was included to provide a clearer image of said latch, would have the latch pushed to the right.
    • After this the battery should pop up and be dislodged
  2. HP Compaq Presario V5303NR Battery Replacement: stap 2, afbeelding 1 van 1
    • Remove the battery from its socket.
Conclusie
Ryan Dunn
197 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team S4-G3, Covino Spring 2018 Lid van UMass Dartmouth, Team S4-G3, Covino Spring 2018
UMASSD-COVINO-S18S4G3
3 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 12
Altijd: 121
