Inleiding
Should the monitor of the laptop stop functioning correctly, you may need to replace the monitor altogether. This is a simple replacement that can be done by removing a few easy screws.
Wat je nodig hebt
Locate and remove four black 5.1mm Phillips #1 screws from the left and right sides of the monitor.
Één andere persoon heeft deze handleiding voltooid.
