Wat je nodig hebt
Orient the monitor screen down on a table. Be careful the work surface is not going to damage the screen when laying flat.
Remove the 4 12 mm screws from the base using a PH2 bit and driver.
Make sure to hold the screen at the bezel when the last stand screw is removed, gently lay the monitor flush with the table after the stand is removed.
4 andere personen hebben deze handleiding voltooid.
