Ga door naar hoofdinhoud
HP Compaq C700 Keyboard Replacement
Wat je nodig hebt
  1. HP Compaq C700 Keyboard Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • It is advised to work on the device only when it is powered off so as to avoid electrocution risks.
    • Turn off computer by pressing and holding the power button.
  2. HP Compaq C700 Keyboard Replacement: stap 2, afbeelding 1 van 3 HP Compaq C700 Keyboard Replacement: stap 2, afbeelding 2 van 3 HP Compaq C700 Keyboard Replacement: stap 2, afbeelding 3 van 3
    • Locate and unscrew the two screws on the back marked with a small keyboard. These screws hold the keyboard in place.
    • Locate the metal hooks where the keyboard connects to the laptop and use a metal spudger to gently pry up the keyboard.
  3. HP Compaq C700 Keyboard Replacement: stap 3, afbeelding 1 van 1
    • Gently lift up and remove the keyboard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Taylor Johansen
690 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 5-6, Martin Fall 2016 Lid van UMass Dartmouth, Team 5-6, Martin Fall 2016
UMASSD-MARTIN-F16S5G6
3 Leden
6 handleidingen geschreven
2Gids Commentaar
er zijn 3 schroeven aan het keyboard
marcel - Antwoord
there is a third screw holding in the keyboard located under the RAM cover not mentioned in this guide, please make sure you remove that too or else you may end up warping your keyboard like my friend did with his C700.
Blackblur610 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 13
Altijd: 825
