Ga door naar hoofdinhoud
HP Compaq 6710b Power Button Panel Replacement
Wat je nodig hebt
  1. HP Compaq 6710b Power Button Panel Replacement, Keyboard: stap 1, afbeelding 1 van 3 HP Compaq 6710b Power Button Panel Replacement, Keyboard: stap 1, afbeelding 2 van 3 HP Compaq 6710b Power Button Panel Replacement, Keyboard: stap 1, afbeelding 3 van 3
    • Turn off computer before starting.
    • Flip to the backside of the laptop.
    • Using a Phillips #1 screwdriver, unscrew the 5mm screw and take off the shown cover.
    • Using the same screwdriver, unscrew the 8mm screws.
    • The screws may not completely fall out of the laptop, just ensure they are unscrewed as far as they will go.
  2. HP Compaq 6710b Power Button Panel Replacement: stap 2, afbeelding 1 van 1
    • Flip over the laptop to the top side, and open the laptop.
    • Slide the locking tabs down using a blue plastic opening tool or your fingernail.
  3. HP Compaq 6710b Power Button Panel Replacement: stap 3, afbeelding 1 van 2 HP Compaq 6710b Power Button Panel Replacement: stap 3, afbeelding 2 van 2
    • Using the plastic prying tool, lift the keyboard gently towards you.
    • Don't take the keyboard completely off because it is still attached with a ribbon cable to the computer.
  4. HP Compaq 6710b Power Button Panel Replacement: stap 4, afbeelding 1 van 1
    • Pull up on both sides of the black locking tab of the connector.
    • The keyboard should now be free of the computer.
  5. HP Compaq 6710b Power Button Panel Replacement, Power Button Panel: stap 5, afbeelding 1 van 1
    • Put a finger under each side of the plastic lock on the ribbon cable and pull up.
  6. HP Compaq 6710b Power Button Panel Replacement: stap 6, afbeelding 1 van 3 HP Compaq 6710b Power Button Panel Replacement: stap 6, afbeelding 2 van 3 HP Compaq 6710b Power Button Panel Replacement: stap 6, afbeelding 3 van 3
    • Using a flathead screwdriver, get under each plastic hinge cover until they pop.
    • Lift the right edge of plastic strip covering the power button and gently pull it up until the whole strip comes free.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Khulan Orgil
1.171 Reputatie
6 handleidingen geschreven
Cal Poly, Team 4-2, Maness Spring 2015 Lid van Cal Poly, Team 4-2, Maness Spring 2015
CPSU-MANESS-S15S4G2
4 Leden
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 28
Altijd: 3,628
