Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
You will need to take out the keyboard as a part of replacing the heat sink. Know the steps to Keyboard Replacement before starting on this.
Wat je nodig hebt
Flip the laptop over to the back.
Using two hands, push on the tabs while gently taking out the battery.
Flip to the backside of the laptop.
Using a Phillips #1 screwdriver, unscrew the 5mm screw and take off the shown cover.
Using the same screwdriver, unscrew the 8mm screws.
Put a finger under each side of the plastic lock on the ribbon cable and pull up.
Using two fingers, open the prongs holding the RAM
Then slide the RAM out from the socket
9 andere personen hebben deze handleiding voltooid.
3 opmerkingen
That was easy. Thanks man :)
Piece of cake ! Thanks. :)
