Ga door naar hoofdinhoud
HP Compaq 2510p WiFi Card Replacement
Wat je nodig hebt
  1. HP Compaq 2510p WiFi Card Replacement, WiFi Card: stap 1, afbeelding 1 van 1
    • Flip the laptop over and locate the RAM cover plate towards the left of the laptop. There will be two screws located on the panel.
  2. HP Compaq 2510p WiFi Card Replacement: stap 2, afbeelding 1 van 1
    • Using your Philips screwdriver, unscrew both screws.
  3. HP Compaq 2510p WiFi Card Replacement: stap 3, afbeelding 1 van 1
    • Lift the plate with your finger to remove it.
  4. HP Compaq 2510p WiFi Card Replacement: stap 4, afbeelding 1 van 2 HP Compaq 2510p WiFi Card Replacement: stap 4, afbeelding 2 van 2
    • Locate the screws at the top of the card and use your Philips screwdriver to remove them.
    • Be sure to ground yourself before touching components.
  5. HP Compaq 2510p WiFi Card Replacement: stap 5, afbeelding 1 van 1
    • Lift the card from underneath the top, using the spudger to leverage the card upwards. Then pull to release the card.
    • Always used ESD safe tools when repairing electronics. The black nylon spudger should be used whenever possible.
  6. HP Compaq 2510p WiFi Card Replacement: stap 6, afbeelding 1 van 1
    • Pull on each of the wires connected to the card. They will easily pop off and the WiFi card will be released.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Dan Champagne
184 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 3-8, Isaacson Fall 2016 Lid van UMass Dartmouth, Team 3-8, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G8
3 Leden
5 handleidingen geschreven
Één opmerking
what wifi cards does this notebook support?
plaui - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 8
Altijd: 642
