Ga door naar hoofdinhoud
HP Compaq 2510p RAM Replacement
Wat je nodig hebt
  1. HP Compaq 2510p RAM Replacement, RAM: stap 1, afbeelding 1 van 1
    • Flip the device over so the back panel is facing upwards. Locate the RAM plate cover towards the left side of the laptop. There will be two screws located on the panel.
  2. HP Compaq 2510p RAM Replacement: stap 2, afbeelding 1 van 1
    • Remove both screws holding the RAM cover plate in place using your Phillips Screwdriver.
  3. HP Compaq 2510p RAM Replacement: stap 3, afbeelding 1 van 1
    • Remove the cover plate by lifting upwards once screws are removed.
  4. HP Compaq 2510p RAM Replacement: stap 4, afbeelding 1 van 1
    • Carefully release the pins that are securing the RAM in place by pushing in a outward motion, away from the RAM.
    • Be sure to ground yourself before touching the RAM.
    • Be gentle when releasing the pins.
  5. HP Compaq 2510p RAM Replacement: stap 5, afbeelding 1 van 1
    • Remove the old RAM by lifting it upwards, then pulling.
Conclusie
Nathan Pereira
57 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 3-8, Isaacson Fall 2016 Lid van UMass Dartmouth, Team 3-8, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G8
3 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 7
Altijd: 884
