Ga door naar hoofdinhoud
HP Compaq 2510p Power/audio bar Replacement
Wat je nodig hebt
  1. HP Compaq 2510p Power/audio bar Replacement, Power/audio bar: stap 1, afbeelding 1 van 1
    • Locate the 4 screws in the four corners of the laptop screen.
    • The screws may be hidden underneath a small rubber pad.
    • Be sure to ground yourself and tools before working near electronics.
  2. HP Compaq 2510p Power/audio bar Replacement: stap 2, afbeelding 1 van 1
    • Use a Flathead screwdriver to remove the 4 rubber covers over the 4 screws referenced in step 1.
  3. HP Compaq 2510p Power/audio bar Replacement: stap 3, afbeelding 1 van 1
    • Once the rubber has been removed a screw will be revealed. Remove each of the four screws with your Philips head screwdriver.
  4. HP Compaq 2510p Power/audio bar Replacement: stap 4, afbeelding 1 van 1
    • Insert your spudger along the top of the screen, separating the plastic cover and the screen
  5. HP Compaq 2510p Power/audio bar Replacement: stap 5, afbeelding 1 van 1
    • Continue running your Flathead along the top of the screen until the top is completely separated.
  6. HP Compaq 2510p Power/audio bar Replacement: stap 6, afbeelding 1 van 2 HP Compaq 2510p Power/audio bar Replacement: stap 6, afbeelding 2 van 2
    • Pull the plastic covering of the screen towards the keyboard, exposing the inner workings of the screen.
  7. HP Compaq 2510p Power/audio bar Replacement: stap 7, afbeelding 1 van 1
    • Locate the hinges at the bottom left, and right of the screen
  8. HP Compaq 2510p Power/audio bar Replacement: stap 8, afbeelding 1 van 2 HP Compaq 2510p Power/audio bar Replacement: stap 8, afbeelding 2 van 2
    • Separate the Power/Audio bar from the hinge by gently pulling.
  9. HP Compaq 2510p Power/audio bar Replacement: stap 9, afbeelding 1 van 1
    • Flip the Power/Audio bar over exposing the ribbon wire and its connection to the Power/Audio bar.
  10. HP Compaq 2510p Power/audio bar Replacement: stap 10, afbeelding 1 van 1
    • Separate the ribbon wire by gently pulling the wire from its socket.
    • The wire will be separated and the bar is free.
    • Be gentle as you pull.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Derek Kohansky
297 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 3-8, Isaacson Fall 2016 Lid van UMass Dartmouth, Team 3-8, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G8
3 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 420
