Inleiding
If the Bottom Shield of your HP Chromebox is damaged, it is easy to replace. This guide will take you through the steps of replacing the bottom shield. For this guide, you will need the Philips #1 screwdriver .
Wat je nodig hebt
Position the device upside-down on a flat, level surface with the USB ports facing you.
Bijna klaar!
Conclusie
