Ga door naar hoofdinhoud
HP Chromebox J5N50UT Bottom Cover Replacement
Wat je nodig hebt
  1. HP Chromebox J5N50UT Bottom Cover Replacement, Bottom Cover: stap 1, afbeelding 1 van 1
    • Before removing the bottom cover, ensure that your computer is powered down and ensure that all external devices are disconnected. If you are unsure whether the computer is off or in hibernation mode, turn the computer on, then shut it down through the operating system.
    • Position the device upside-down on a flat, level surface with the USB ports facing you.
  2. HP Chromebox J5N50UT Bottom Cover Replacement: stap 2, afbeelding 1 van 1
    • Using your metal spudger, lift and remove the 4 rubber “feet” from each corner.
  3. HP Chromebox J5N50UT Bottom Cover Replacement: stap 3, afbeelding 1 van 1
    • Using your Phillips head screwdriver, remove the four Phillips M2.5×4.0 screws that secure the bottom cover to the computer. In this step the usage of the magnetic mat will be helpful to keep up with the screws.
  4. HP Chromebox J5N50UT Bottom Cover Replacement: stap 4, afbeelding 1 van 1
    • Insert the flat end of your metal spudger under the bottom cover near the USB ports, then pry the bottom cover off the computer.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Ashley Marvin
685 Reputatie
5 handleidingen geschreven
Ohio State, Team S1-G3, Whitney Fall 2018 Lid van Ohio State, Team S1-G3, Whitney Fall 2018
OSU-WHITNEY-F18S1G3
2 Leden
Één opmerking
Can you explain how/where the integrated VESA mount is?
Is the mounting screw holes under the rubber feet, like other chromeboxes, from other makers?
When Ze - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 16
Altijd: 578
