Inleiding
This guide outlines how to remove the heat sink of an HP Chromebook x360 14c-ca0053. The heat sink functions to conduct heat to the fans without overheating the device. A malfunctioning heat sink could lead to device failure and is indicated by frequent overheating, so it is important to replace it if it is not working properly. Before reassembly, the thermal paste must be reapplied for proper function.
Wat je nodig hebt
Use a Phillips #0 screwdriver to remove the four 3 mm screws that secure the heatsink.
