Ga door naar hoofdinhoud
HP Chromebook x360 14c-ca0053 Battery Replacement
Wat je nodig hebt
  1. HP Chromebook x360 14c-ca0053 Battery Replacement, Lower Case: stap 1, afbeelding 1 van 2 HP Chromebook x360 14c-ca0053 Battery Replacement, Lower Case: stap 1, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Use tweezers to apply light pressure on the outer sides of the 2 small screw covers located near the bottom of the device.
    • Rotate the covers until they pop up out of the screw socket enough to remove them with tweezers.
  2. HP Chromebook x360 14c-ca0053 Battery Replacement: stap 2, afbeelding 1 van 2 HP Chromebook x360 14c-ca0053 Battery Replacement: stap 2, afbeelding 2 van 2
    • Use a Phillips #1 screwdriver to remove the two 3.5 mm screws.
  3. HP Chromebook x360 14c-ca0053 Battery Replacement: stap 3, afbeelding 1 van 3 HP Chromebook x360 14c-ca0053 Battery Replacement: stap 3, afbeelding 2 van 3 HP Chromebook x360 14c-ca0053 Battery Replacement: stap 3, afbeelding 3 van 3
    • Use tweezers to peel back the feet on the top and bottom of the Chromebook to reveal four additional screws.
  4. HP Chromebook x360 14c-ca0053 Battery Replacement: stap 4, afbeelding 1 van 2 HP Chromebook x360 14c-ca0053 Battery Replacement: stap 4, afbeelding 2 van 2
    • Use a Phillips #1 screwdriver to remove the 4 7 mm screws located at each corner of the device under the grips.
  5. HP Chromebook x360 14c-ca0053 Battery Replacement: stap 5, afbeelding 1 van 3 HP Chromebook x360 14c-ca0053 Battery Replacement: stap 5, afbeelding 2 van 3 HP Chromebook x360 14c-ca0053 Battery Replacement: stap 5, afbeelding 3 van 3
    • Insert an opening pick between lower case and chassis.
    • Separate the lower case from the frame by sliding the opening pick along the perimeter until the case releases.
  6. HP Chromebook x360 14c-ca0053 Battery Replacement: stap 6, afbeelding 1 van 1
    • Lift the lower case up and off.
  7. HP Chromebook x360 14c-ca0053 Battery Replacement, Battery: stap 7, afbeelding 1 van 3 HP Chromebook x360 14c-ca0053 Battery Replacement, Battery: stap 7, afbeelding 2 van 3 HP Chromebook x360 14c-ca0053 Battery Replacement, Battery: stap 7, afbeelding 3 van 3
    Koop
    • Open the tweezers wide enough to fit on each side of motherboard battery connection.
    • Pull the connector directly out of its socket.
  8. HP Chromebook x360 14c-ca0053 Battery Replacement: stap 8, afbeelding 1 van 2 HP Chromebook x360 14c-ca0053 Battery Replacement: stap 8, afbeelding 2 van 2
    • Use a Phillips #0 screwdriver to remove the five 3 mm screws that secure the battery.
    • These screws are labeled 1-5.
  9. HP Chromebook x360 14c-ca0053 Battery Replacement: stap 9, afbeelding 1 van 1
    • Lift the battery up and out.
    • Be careful as to not puncture or damage the battery.
Conclusie
Cassidy
691 Reputatie
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 18
Altijd: 109
