Inleiding
You may need to replace the battery if you have a faulty battery. It will require you to take the back of the computer off and replace the battery internally. There are no hazards accompanied with this task as long as the Chromebook is not charging.
Wat je nodig hebt
Once it is opened up, locate the battery and the cable that is attached to it.
3 andere personen hebben deze handleiding voltooid.
