Ga door naar hoofdinhoud
HP Chromebook 14-x013dx Speakers Replacement
Wat je nodig hebt
  1. HP Chromebook 14-x013dx Speakers Replacement, Keyboard, Touchpad: stap 1, afbeelding 1 van 2 HP Chromebook 14-x013dx Speakers Replacement, Keyboard, Touchpad: stap 1, afbeelding 2 van 2
    • Using the plastic spudger, gently lift the 5 rubber pads away from their seating.
  2. HP Chromebook 14-x013dx Speakers Replacement: stap 2, afbeelding 1 van 1
    • Remove the five 6mm screws located under the removed pads using Phillips #00 screwdriver.
  3. HP Chromebook 14-x013dx Speakers Replacement: stap 3, afbeelding 1 van 2 HP Chromebook 14-x013dx Speakers Replacement: stap 3, afbeelding 2 van 2
    • With the Phillips #00 screwdriver, remove the remaining eight 6mm screws. You will now have thirteen 6mm screws removed from the case.
  4. HP Chromebook 14-x013dx Speakers Replacement: stap 4, afbeelding 1 van 2 HP Chromebook 14-x013dx Speakers Replacement: stap 4, afbeelding 2 van 2
    • To continue removing the back cover, turn the laptop over as displayed.
    • Use the plastic spudger to gently pry around the base of the laptop from the back cover. Continue prying around the entire base of the laptop.
  5. HP Chromebook 14-x013dx Speakers Replacement: stap 5, afbeelding 1 van 3 HP Chromebook 14-x013dx Speakers Replacement: stap 5, afbeelding 2 van 3 HP Chromebook 14-x013dx Speakers Replacement: stap 5, afbeelding 3 van 3
    • Gently lift the silver base of the laptop from the bottom, but do not remove it.
    • To remove the ribbon cables, lift the latch holding the ribbon cables in place and then pull them free.
    • Remove the keyboard panel from the laptop.
  6. HP Chromebook 14-x013dx Speakers Replacement, Battery: stap 6, afbeelding 1 van 2 HP Chromebook 14-x013dx Speakers Replacement, Battery: stap 6, afbeelding 2 van 2
    • Remove the eight 4mm screws holding the battery in place using the Phillips #00 screwdriver.
  7. HP Chromebook 14-x013dx Speakers Replacement: stap 7, afbeelding 1 van 2 HP Chromebook 14-x013dx Speakers Replacement: stap 7, afbeelding 2 van 2
    • Remove the ribbon cable that runs over the battery by lifting up the plastic latches and pulling the cable away.
  8. HP Chromebook 14-x013dx Speakers Replacement: stap 8, afbeelding 1 van 2 HP Chromebook 14-x013dx Speakers Replacement: stap 8, afbeelding 2 van 2
    • Unhook the battery's power connector from the motherboard.
  9. HP Chromebook 14-x013dx Speakers Replacement: stap 9, afbeelding 1 van 1
    • Lift the battery out of the laptop case.
  10. HP Chromebook 14-x013dx Speakers Replacement, Speakers: stap 10, afbeelding 1 van 2 HP Chromebook 14-x013dx Speakers Replacement, Speakers: stap 10, afbeelding 2 van 2
    • Unplug Speaker from motherboard.
  11. HP Chromebook 14-x013dx Speakers Replacement: stap 11, afbeelding 1 van 2 HP Chromebook 14-x013dx Speakers Replacement: stap 11, afbeelding 2 van 2
    • Pull the left and right speaker out carefully.
    • The corners of the the speakers will be held in place by tape, and may require a bit of force.
  12. HP Chromebook 14-x013dx Speakers Replacement: stap 12, afbeelding 1 van 2 HP Chromebook 14-x013dx Speakers Replacement: stap 12, afbeelding 2 van 2
    • Remove the black tape holding the wire to the laptop casing.
    • Remove the wires from the three hooks on the case.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
NHerbert
602 Reputatie
5 handleidingen geschreven
USF Tampa, Team S3-G6, Nance Fall 2017 Lid van USF Tampa, Team S3-G6, Nance Fall 2017
USFT-NANCE-F17S3G6
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 4
Altijd: 238
