Ga door naar hoofdinhoud
HP Chromebook 14-x013dx Keyboard/Touchpad Replacement
Wat je nodig hebt
  1. HP Chromebook 14-x013dx Keyboard/Touchpad Replacement, Keyboard, Touchpad: stap 1, afbeelding 1 van 2 HP Chromebook 14-x013dx Keyboard/Touchpad Replacement, Keyboard, Touchpad: stap 1, afbeelding 2 van 2
    • Using the plastic spudger, gently lift the 5 rubber pads away from their seating.
  2. HP Chromebook 14-x013dx Keyboard/Touchpad Replacement: stap 2, afbeelding 1 van 1
    • Remove the five 6mm screws located under the removed pads using Phillips #00 screwdriver.
  3. HP Chromebook 14-x013dx Keyboard/Touchpad Replacement: stap 3, afbeelding 1 van 2 HP Chromebook 14-x013dx Keyboard/Touchpad Replacement: stap 3, afbeelding 2 van 2
    • With the Phillips #00 screwdriver, remove the remaining eight 6mm screws. You will now have thirteen 6mm screws removed from the case.
  4. HP Chromebook 14-x013dx Keyboard/Touchpad Replacement: stap 4, afbeelding 1 van 2 HP Chromebook 14-x013dx Keyboard/Touchpad Replacement: stap 4, afbeelding 2 van 2
    • To continue removing the back cover, turn the laptop over as displayed.
    • Use the plastic spudger to gently pry around the base of the laptop from the back cover. Continue prying around the entire base of the laptop.
  5. HP Chromebook 14-x013dx Keyboard/Touchpad Replacement: stap 5, afbeelding 1 van 3 HP Chromebook 14-x013dx Keyboard/Touchpad Replacement: stap 5, afbeelding 2 van 3 HP Chromebook 14-x013dx Keyboard/Touchpad Replacement: stap 5, afbeelding 3 van 3
    • Gently lift the silver base of the laptop from the bottom, but do not remove it.
    • To remove the ribbon cables, lift the latch holding the ribbon cables in place and then pull them free.
    • Remove the keyboard panel from the laptop.
Conclusie
4 andere personen hebben deze handleiding voltooid.
NHerbert
602 Reputatie
5 handleidingen geschreven
USF Tampa, Team S3-G6, Nance Fall 2017 Lid van USF Tampa, Team S3-G6, Nance Fall 2017
USFT-NANCE-F17S3G6
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 9
Altijd: 1,269
