Ga door naar hoofdinhoud
HP Chromebook 14-x013dx Camera Replacement
Wat je nodig hebt
  1. HP Chromebook 14-x013dx Camera Replacement, Keyboard, Touchpad: stap 1, afbeelding 1 van 2 HP Chromebook 14-x013dx Camera Replacement, Keyboard, Touchpad: stap 1, afbeelding 2 van 2
    • Using the plastic spudger, gently lift the 5 rubber pads away from their seating.
  2. HP Chromebook 14-x013dx Camera Replacement: stap 2, afbeelding 1 van 1
    • Remove the five 6mm screws located under the removed pads using Phillips #00 screwdriver.
  3. HP Chromebook 14-x013dx Camera Replacement: stap 3, afbeelding 1 van 2 HP Chromebook 14-x013dx Camera Replacement: stap 3, afbeelding 2 van 2
    • With the Phillips #00 screwdriver, remove the remaining eight 6mm screws. You will now have thirteen 6mm screws removed from the case.
  4. HP Chromebook 14-x013dx Camera Replacement: stap 4, afbeelding 1 van 2 HP Chromebook 14-x013dx Camera Replacement: stap 4, afbeelding 2 van 2
    • To continue removing the back cover, turn the laptop over as displayed.
    • Use the plastic spudger to gently pry around the base of the laptop from the back cover. Continue prying around the entire base of the laptop.
  5. HP Chromebook 14-x013dx Camera Replacement: stap 5, afbeelding 1 van 3 HP Chromebook 14-x013dx Camera Replacement: stap 5, afbeelding 2 van 3 HP Chromebook 14-x013dx Camera Replacement: stap 5, afbeelding 3 van 3
    • Gently lift the silver base of the laptop from the bottom, but do not remove it.
    • To remove the ribbon cables, lift the latch holding the ribbon cables in place and then pull them free.
    • Remove the keyboard panel from the laptop.
  6. HP Chromebook 14-x013dx Camera Replacement, Camera: stap 6, afbeelding 1 van 2 HP Chromebook 14-x013dx Camera Replacement, Camera: stap 6, afbeelding 2 van 2
    • Disconnect the black and white wires connected to the Wi-Fi module.
    • Remove the wire from the casing.
  7. HP Chromebook 14-x013dx Camera Replacement: stap 7, afbeelding 1 van 1
    • Pull the ribbon cable out of socket.
  8. HP Chromebook 14-x013dx Camera Replacement: stap 8, afbeelding 1 van 3 HP Chromebook 14-x013dx Camera Replacement: stap 8, afbeelding 2 van 3 HP Chromebook 14-x013dx Camera Replacement: stap 8, afbeelding 3 van 3
    • Use a Phillips #00 screwdriver to remove the two 6mm screws located at the upper left and right corners.
  9. HP Chromebook 14-x013dx Camera Replacement: stap 9, afbeelding 1 van 2 HP Chromebook 14-x013dx Camera Replacement: stap 9, afbeelding 2 van 2
    • Remove the lid out of the laptop.
    • It is helpful to rotate the lid to a 90-degree angle.
  10. HP Chromebook 14-x013dx Camera Replacement: stap 10, afbeelding 1 van 1
    • Using the plastic opening tool, pry the left and right side of the top of the lid.
    • It is not necessary to remove the entire frame, only pry the top to expose the camera.
  11. HP Chromebook 14-x013dx Camera Replacement: stap 11, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Using tweezers, gently remove the connection hold the camera in place.
  12. HP Chromebook 14-x013dx Camera Replacement: stap 12, afbeelding 1 van 2 HP Chromebook 14-x013dx Camera Replacement: stap 12, afbeelding 2 van 2
    • Gently pry the camera mount out of the lid.
    • Lift the camera mount out of the lid.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Eile Woeltje
304 Reputatie
2 handleidingen geschreven
IUPUI, Team S1-G3, Stella Fall 2019 Lid van IUPUI, Team S1-G3, Stella Fall 2019
IUPUI-STELLA-F19S1G3
3 Leden
Één opmerking
Thank you, very helpful. You could also just start at Step 10 without removing the display
Douglas Walker - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 9
Altijd: 776
