Ga door naar hoofdinhoud
HP Chromebook 14-q010nr Motherboard Replacement
Wat je nodig hebt
  1. HP Chromebook 14-q010nr Motherboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Begin by turning the Chromebook onto its back.
    • Remove the 15 screws with a Phillips #0 screwdriver.
    • Four screws will be located underneath the device's rubber foot pads.
  2. HP Chromebook 14-q010nr Motherboard Replacement: stap 2, afbeelding 1 van 3 HP Chromebook 14-q010nr Motherboard Replacement: stap 2, afbeelding 2 van 3 HP Chromebook 14-q010nr Motherboard Replacement: stap 2, afbeelding 3 van 3
    • Remove the keyboard from the base plate with an opening pick to pry it open from both sides of the keyboard.
    • Beginning from the corners closest to the computer screen may result in easier disconnection.
  3. HP Chromebook 14-q010nr Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Use a Phillips #0 screwdriver to remove the seven screws securing the battery.
  4. HP Chromebook 14-q010nr Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Gently disconnect the battery's motherboard connection by pinching the white attachment and pulling the plug directly out of the port.
  5. HP Chromebook 14-q010nr Motherboard Replacement: stap 5, afbeelding 1 van 2 HP Chromebook 14-q010nr Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Before removing the battery, gently lift the white ribbon cable taped to the battery.
    • Gently pull up from the back of the battery to remove it.
  6. HP Chromebook 14-q010nr Motherboard Replacement, Motherboard: stap 6, afbeelding 1 van 1
    • Remove the eleven motherboard screws with a 2mm Phillips screwdriver.
  7. HP Chromebook 14-q010nr Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Remove the white ribbon cable from the motherboard by lifting the black ZIF connector.
  8. HP Chromebook 14-q010nr Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Remove the five screws attached to the connector plate.
    • Remove the monitor connector by lifting it gently upward.
  9. HP Chromebook 14-q010nr Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Remove the antenna cables on the right side of the motherboard.
    • Carefully lift the motherboard up to remove it. Use a spudger for ease.
Conclusie
Julian Knight
159 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 153
