Ga door naar hoofdinhoud
HP Chromebook 14-ca061dx Display Replacement
Wat je nodig hebt
  1. HP Chromebook 14-ca061dx Display Replacement, Display: stap 1, afbeelding 1 van 3 HP Chromebook 14-ca061dx Display Replacement, Display: stap 1, afbeelding 2 van 3 HP Chromebook 14-ca061dx Display Replacement, Display: stap 1, afbeelding 3 van 3
    • Flip the Chromebook so that the underside is facing upwards.
    • Follow along the edge with the iFixit opening tool to unhinge the display frame.
  2. HP Chromebook 14-ca061dx Display Replacement: stap 2, afbeelding 1 van 1
    • Flip the Chromebook right side up and open it to form a 180 degree angle.
  3. HP Chromebook 14-ca061dx Display Replacement: stap 3, afbeelding 1 van 1
    • Use the iFixit opening tool to pry open the bezel. Start from the bottom of the screen and work your way around the sides.
    • The bottom edge of the bezel may stick because there is glue holding it together.
  4. HP Chromebook 14-ca061dx Display Replacement: stap 4, afbeelding 1 van 2 HP Chromebook 14-ca061dx Display Replacement: stap 4, afbeelding 2 van 2
    • Use spudger or the iFixit opening tool to remove the bezel.
    • When prying, be careful not to damage or snap bezel. This is made up of very, thin plastic.
    • Pull bezel from the bottom, once all clips are detached.
    • Remove bezel.
  5. HP Chromebook 14-ca061dx Display Replacement: stap 5, afbeelding 1 van 2 HP Chromebook 14-ca061dx Display Replacement: stap 5, afbeelding 2 van 2
    • Remove the four 2mm JIS #000 screws.
  6. HP Chromebook 14-ca061dx Display Replacement: stap 6, afbeelding 1 van 2 HP Chromebook 14-ca061dx Display Replacement: stap 6, afbeelding 2 van 2
    • Use tweezers to pull the tape back and remove the connector attached to the back of the LCD panel.
    • Be cautious when pulling back the tape—the connector/ribbon is fragile and could snap easily.
  7. HP Chromebook 14-ca061dx Display Replacement: stap 7, afbeelding 1 van 1
    • Remove the LCD/display panel from the Chromebook frame.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jean Arevalo
778 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team S2-G5, Barthe Fall 2019 Lid van UMass Dartmouth, Team S2-G5, Barthe Fall 2019
UMASSD-BARTHE-F19S2G5
3 Leden
Één opmerking
should disconnect the laptop battery first
TJ Kleckner - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 15
Altijd: 2,597
