Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
If your HP Chromebook 14-ca061dx is not charging, won’t turn on, or continuously shuts off by itself and you have determined that that battery needs replacing, you can replace it with this guide. Be sure to remove all the internal pieces with caution, for they can be broken easily. Before opening up the Chromebook, make sure the battery is completely drained because having a charged battery could be a hazard.
  1. Flip the Chromebook to the underside with the hinge at the top. Remove  the seven, small rubber stoppers using angled tweezers. Remove  the seven, small rubber stoppers using angled tweezers.
    • Flip the Chromebook to the underside with the hinge at the top.
    • Remove the seven, small rubber stoppers using angled tweezers.
  2. Remove the two bigger rubber stoppers using a metal spudger. Remove the two bigger rubber stoppers using a metal spudger. Remove the two bigger rubber stoppers using a metal spudger.
    • Remove the two bigger rubber stoppers using a metal spudger.
  3. Remove the seven 6mm Phillips #00 screws found underneath the stoppers. Remove the seven 6mm Phillips #00 screws found underneath the stoppers.
    • Remove the seven 6mm Phillips #00 screws found underneath the stoppers.
  4. Remove the two 9mm Phillips #1 screws. Remove the two 9mm Phillips #1 screws.
    • Remove the two 9mm Phillips #1 screws.
  5. SLA DE UPGRADE OVER
    Bespaar door het te repareren met een alles-in-één kit.
    Koop iPhone-reparatiekits
    SLA DE UPGRADE OVER
  6. Flip the Chromebook over and open the cover. Insert the iFixit opening tool into the edge of the keyboard, near the mouse pad. By lifting the tool at an angle, work the tool around the entire perimeter of the  keyboard.
    • Flip the Chromebook over and open the cover.
    • Insert the iFixit opening tool into the edge of the keyboard, near the mouse pad.
    • By lifting the tool at an angle, work the tool around the entire perimeter of the keyboard.
    • You will hear a popping noise when you disconnect the keyboard.
  7. Lift the keyboard  from the mouse pad. Lift the keyboard carefully, because there are cables connecting the keyboard to the base and they may break. Use your finger or the spudger tool to flip up the black  locking flap.
    • Lift the keyboard from the mouse pad.
    • Lift the keyboard carefully, because there are cables connecting the keyboard to the base and they may break.
    • Use your finger or the spudger tool to flip up the black locking flap.
    • Grab the black cable and pull away from the motherboard.
    • Carefully lift the black piece up, because it is fragile and can break easily.
  8. Flip up the white  locking  flap  with your finger or spudger tool. Remove the  white  cable  from the motherboard. Carefully lift the white piece up, because it is fragile and can break easily.
    • Flip up the white locking flap with your finger or spudger tool.
    • Remove the white cable from the motherboard.
    • Carefully lift the white piece up, because it is fragile and can break easily.
  9. Lift the rest of the keyboard up from the base of the Chromebook.
    • Lift the rest of the keyboard up from the base of the Chromebook.
  10. Remove the four 4mm Phillips #0 screws from the battery. Remove the four 4mm Phillips #0 screws from the battery.
    • Remove the four 4mm Phillips #0 screws from the battery.
  11. Peel back the black electrical  tape from the motherboard using a pair of tweezers. Using  your finger, pull the white plastic  piece toward you. Using  your finger, pull the white plastic  piece toward you.
    • Peel back the black electrical tape from the motherboard using a pair of tweezers.
    • Using your finger, pull the white plastic piece toward you.
  12. Remove the battery from the base of the Chromebook.
    • Remove the battery from the base of the Chromebook.
Conclusie
Jean Arevalo
751 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team S2-G5, Barthe Fall 2019 Lid van UMass Dartmouth, Team S2-G5, Barthe Fall 2019
UMASSD-BARTHE-F19S2G5
3 Leden
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 26
Altijd: 387
