Inleiding
If your HP Chromebook 14-ca061dx is not charging, won’t turn on, or continuously shuts off by itself and you have determined that that battery needs replacing, you can replace it with this guide. Be sure to remove all the internal pieces with caution, for they can be broken easily. Before opening up the Chromebook, make sure the battery is completely drained because having a charged battery could be a hazard.
Wat je nodig hebt
Flip the Chromebook to the underside with the hinge at the top.
Remove the seven, small rubber stoppers using angled tweezers.
4 andere personen hebben deze handleiding voltooid.
