Ga door naar hoofdinhoud
HP Chromebook 14-Q070NR Keyboard Replacement
Wat je nodig hebt
  1. HP Chromebook 14-Q070NR Keyboard Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • At this point, the white caps that hide the top-most screws marked with red circles have been removed.
    • Using the Phillips #1 screwdriver, remove the (10) ten screws from the bottom of the device.
    • After removing the white caps covering the screws, use the Phillips #1 screwdriver to remove the (3) three screws indicated with red circles.
  2. HP Chromebook 14-Q070NR Keyboard Replacement: stap 2, afbeelding 1 van 3 HP Chromebook 14-Q070NR Keyboard Replacement: stap 2, afbeelding 2 van 3 HP Chromebook 14-Q070NR Keyboard Replacement: stap 2, afbeelding 3 van 3
    • Open the laptop and place it upright. Remove the keyboard from the device using a plastic spudger or opening tool.
    • Carefully remove as there are ribbons attached to the keyboard that is connected to the components inside.
    • Gently lift the keyboard just enough to expose the ribbons.
  3. HP Chromebook 14-Q070NR Keyboard Replacement: stap 3, afbeelding 1 van 3 HP Chromebook 14-Q070NR Keyboard Replacement: stap 3, afbeelding 2 van 3 HP Chromebook 14-Q070NR Keyboard Replacement: stap 3, afbeelding 3 van 3
    • Hold the keyboard up to remove the ribbons from the circuit board.
    • To remove each individual ribbon, grab the blue portion of each ribbon and pull it towards your direction until it is fully detached.
  4. HP Chromebook 14-Q070NR Keyboard Replacement: stap 4, afbeelding 1 van 3 HP Chromebook 14-Q070NR Keyboard Replacement: stap 4, afbeelding 2 van 3 HP Chromebook 14-Q070NR Keyboard Replacement: stap 4, afbeelding 3 van 3
    • Once the ribbons are detached, remove the keyboard from the device.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Alexandra Bagarra
122 Reputatie
1 Handleiding geschreven
USF Tampa, Team S9-G5, Remmell Fall 2017 Lid van USF Tampa, Team S9-G5, Remmell Fall 2017
USFT-REMMELL-F17S9G5
5 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 7
Altijd: 297
