Ga door naar hoofdinhoud
HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement
Wat je nodig hebt
  1. HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement, Keyboard and Touchpad: stap 1, afbeelding 1 van 2 HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement, Keyboard and Touchpad: stap 1, afbeelding 2 van 2
    • Flip the laptop with the base of the laptop is facing you.
    • Using the #00 screwdriver, unscrew these screws.
  2. HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement: stap 2, afbeelding 1 van 3 HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement: stap 2, afbeelding 2 van 3 HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement: stap 2, afbeelding 3 van 3
    • Warning! When prying open a laptop it could require some force, but it also has fragile connectors underneath. Use caution so as to avoid breaking these connectors.
    • Start from the top right corner of the laptop and work clockwise with an iFixit opening tool or spudger to pry the keyboard from the frame of the laptop.
  3. HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement: stap 3, afbeelding 1 van 3 HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement: stap 3, afbeelding 2 van 3 HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement: stap 3, afbeelding 3 van 3
    • Warning! Handle the flaps and ribbon cables with care to prevent damage.
    • Gently pull the keyboard in the opposite direction of the screen, so the wires beneath are exposed.
    • Lift the black flap and pull the blue ribbon gently towards you until it is disconnected.
    • Lift the white flap and pull the blue ribbon towards you until it is disconnected.
  4. HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement: stap 4, afbeelding 1 van 1
    • Lift keyboard slightly and remove the strip gently to prevent damaging any parts.
    • The tape has no function other than to keep the wire tucked away.
  5. HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement: stap 5, afbeelding 1 van 1
    • Set aside the detached keyboard.
  6. HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement, Bluetooth and Wireless Card: stap 6, afbeelding 1 van 2 HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement, Bluetooth and Wireless Card: stap 6, afbeelding 2 van 2
    • Using a spudger, remove the white and black cables from the card.
  7. HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement: stap 7, afbeelding 1 van 2 HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement: stap 7, afbeelding 2 van 2
    • Remove screw from card.
  8. HP Chromebook 14-Q010DX Bluetooth and Wireless Card Replacement: stap 8, afbeelding 1 van 1
    • Gently pull card at a 45° angle to remove it.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Kevin Piper
1.599 Reputatie
6 handleidingen geschreven
USF Tampa, Team 17-2, Watkins Winter 2015 Lid van USF Tampa, Team 17-2, Watkins Winter 2015
USFT-WATKINS-W15S17G2
4 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 14
Altijd: 1,704
