Inleiding
Easy and quick replacement of the Chromebook screen.
Wat je nodig hebt
We will be replacing the screen on this HP Chromebook. ***Unfortunately I did get a shot of the sweet crack on this screen.
We will start by removing this screws on the bottom left and right of the screen, just above the escape key and power button.
Next will start to remove the front "bezel" with a simple spudger. It is best to start from the bottom (now we here) of the screen. *couldn't resist
I found a really annoying super sticky black/silverfoil tape that was attached to the bezel and the actual panel, It was quite a bother to remove the bezel because of this. Please consider that this can happen when you try to wedge it off. (the reason it possibly isn't budging can be this tape)
2 opmerkingen
That ribbon connector sure is finicky, It's really hard to actually pop it back in without putting too much force to it and bending it up. (for me atleast)
