Ga door naar hoofdinhoud
HP Chromebook 11a-nb0013dx Motherboard Replacement
Wat je nodig hebt
  1. HP Chromebook 11a-nb0013dx Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 2 HP Chromebook 11a-nb0013dx Motherboard Replacement, Motherboard: stap 1, afbeelding 2 van 2
    • Position the Chromebook with the bottom facing up.
    • Locate the 8 screws on the back of the Chromebook.
    • Next, remove the 8 (8mm) screws using the phillips screw driver with the #0 bit.
  2. HP Chromebook 11a-nb0013dx Motherboard Replacement: stap 2, afbeelding 1 van 2 HP Chromebook 11a-nb0013dx Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Locate the 4 rubber feet on the bottom of the laptop.
    • Pry them off with the metal spudger or an iFixit opening pick.
  3. HP Chromebook 11a-nb0013dx Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Flip over and open the Chromebook.
    • Locate the seem surrounding the keyboard and track pad.
    • Use an iFixit opening pick to pry the keyboard from the laptop
  4. HP Chromebook 11a-nb0013dx Motherboard Replacement: stap 4, afbeelding 1 van 3 HP Chromebook 11a-nb0013dx Motherboard Replacement: stap 4, afbeelding 2 van 3 HP Chromebook 11a-nb0013dx Motherboard Replacement: stap 4, afbeelding 3 van 3
    • Gentally lift up the keyboard and locate the two ribbons attatched to the motherboard.
    • Use the IFixit Opening Tool to lift the two tabs located on the zero insertion force (ZIF) connectors.
    • To do this, use the tip of the IFixit Opening Tool to flip up the small locking flap and gently pull the ribbon out.
    • Then, fully remove the keyboard and set aside.
  5. HP Chromebook 11a-nb0013dx Motherboard Replacement: stap 5, afbeelding 1 van 2 HP Chromebook 11a-nb0013dx Motherboard Replacement: stap 5, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Locate the bundled cable connector connecting the battery to the motherboard.
    • Use the precision tweezers to peel back the black tape covering the bundled cable connector.
    • Next, use the precision tweezers to grab the edge of the connector and slowly pull the cable towards you.
  6. HP Chromebook 11a-nb0013dx Motherboard Replacement: stap 6, afbeelding 1 van 3 HP Chromebook 11a-nb0013dx Motherboard Replacement: stap 6, afbeelding 2 van 3 HP Chromebook 11a-nb0013dx Motherboard Replacement: stap 6, afbeelding 3 van 3
    • Locate the bundled cable connector connecting the speakers to the motherboard.
    • Using the precision tweezers, peel back the plastic that is covering the bundled cable connector.
    • Then, use the precision tweezers to grab the edges of the bundled cable connector and remove by pulling towards the battery.
  7. HP Chromebook 11a-nb0013dx Motherboard Replacement: stap 7, afbeelding 1 van 2 HP Chromebook 11a-nb0013dx Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Locate the LDC cable connecting the screen to the motherboard.
    • Using the precision tweezers, peel back the plastic covering the LDC cable connector.
    • Then, use the precision tweezers to gently pull back the LDC cable towards the screen.
  8. HP Chromebook 11a-nb0013dx Motherboard Replacement: stap 8, afbeelding 1 van 3 HP Chromebook 11a-nb0013dx Motherboard Replacement: stap 8, afbeelding 2 van 3 HP Chromebook 11a-nb0013dx Motherboard Replacement: stap 8, afbeelding 3 van 3
    • Locate the ribbons and their ZIF connectors connecting the motherboard and the daughterboard.
    • Use the precision tweezers to peel back the plastic and uncover the ZIF connectors located at the end of each ribbon.
    • Use the IFixit Opening Tool to flip up the locking flap holding the ribons in place.
    • Then, gently pull out each ribon.
    • On the top left corner of the motherboard, gently unplug the bundled cable from the motherboard.
  9. HP Chromebook 11a-nb0013dx Motherboard Replacement: stap 9, afbeelding 1 van 3 HP Chromebook 11a-nb0013dx Motherboard Replacement: stap 9, afbeelding 2 van 3 HP Chromebook 11a-nb0013dx Motherboard Replacement: stap 9, afbeelding 3 van 3
    • Locate the 6 screws holding the motherboard in place.
    • Using the philips screw driver with the #0 bit, unscrew the 6 (4mm) screws and set them aside.
    • After all the screws are removed, remove the USB-C bracket in the top right hand corner and set aside.
  10. HP Chromebook 11a-nb0013dx Motherboard Replacement: stap 10, afbeelding 1 van 2 HP Chromebook 11a-nb0013dx Motherboard Replacement: stap 10, afbeelding 2 van 2
    • Once the motherboard is not connected to any other components of the Chromebook, gentely remove.
    • When removing the motherboard, lift up and to the left.
Conclusie
Ava Corona
281 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 29
Altijd: 320
