Ga door naar hoofdinhoud
HP Chromebook 11a-nb0013dx Battery Replacement
Wat je nodig hebt
  1. HP Chromebook 11a-nb0013dx Battery Replacement, Battery: stap 1, afbeelding 1 van 2 HP Chromebook 11a-nb0013dx Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Position your closed computer on a flat surface, with the back facing up.
    • Remove all eight 8 mm Philips #0 screws from the bottom cover.
  2. HP Chromebook 11a-nb0013dx Battery Replacement: stap 2, afbeelding 1 van 2 HP Chromebook 11a-nb0013dx Battery Replacement: stap 2, afbeelding 2 van 2
    • Remove the 4 rubber feet with a nylon spudger or an opening tool.
  3. HP Chromebook 11a-nb0013dx Battery Replacement: stap 3, afbeelding 1 van 1
    • Flip over your computer and open it.
    • Using a plastic pick, level up the edges of the keyboard by sliding the pick along the gap.
    • Apply downward pressure to separate the bottom of the Chromebook and the keyboard.
    • Do the same for all 4 sides of the keyboard until it starts to lift.
    • You should hear popping sounds as you slide the plastic pick along the edge.
  4. HP Chromebook 11a-nb0013dx Battery Replacement: stap 4, afbeelding 1 van 1
    • Gently lift up the keyboard from the bottom.
  5. HP Chromebook 11a-nb0013dx Battery Replacement: stap 5, afbeelding 1 van 2 HP Chromebook 11a-nb0013dx Battery Replacement: stap 5, afbeelding 2 van 2
    • Identify the zero insertion force (ZIF) connector.
    • Now, disconnect the cable by using the tip of the iFixit opening tool or your fingernail to flip up the small locking flap.
    • You can now gently pull out the cable.
    • No force is needed to plug in or remove the cable.
  6. HP Chromebook 11a-nb0013dx Battery Replacement: stap 6, afbeelding 1 van 2 HP Chromebook 11a-nb0013dx Battery Replacement: stap 6, afbeelding 2 van 2
    • Identify the second cable and the ZIF connector attatching the cable to the motherboard. Then, unclip it with the iFixit opening tool.
    • To do this, use the iFixit opening tool to flip up the small locking flap located on the ZIF connector.
    • Proceed by gently pulling the cable straight out of the connector to disconnect the cable.
    • Be careful, the cord is very fragile!
  7. HP Chromebook 11a-nb0013dx Battery Replacement: stap 7, afbeelding 1 van 1
    • Once the white cord is removed, this is what it should look like. At this point, you should be able to completely take off the keyboard.
  8. HP Chromebook 11a-nb0013dx Battery Replacement: stap 8, afbeelding 1 van 2 HP Chromebook 11a-nb0013dx Battery Replacement: stap 8, afbeelding 2 van 2
    • Lift up the adhesive holding the battery connector.
    • Then, pull the battery connector straight towards you.
    • It is important to pull of the battery connector straight towards you to avoid breaking the vord.
  9. HP Chromebook 11a-nb0013dx Battery Replacement: stap 9, afbeelding 1 van 2 HP Chromebook 11a-nb0013dx Battery Replacement: stap 9, afbeelding 2 van 2
    • Remove the four 4 mm Philips #00 screws.
  10. HP Chromebook 11a-nb0013dx Battery Replacement: stap 10, afbeelding 1 van 2 HP Chromebook 11a-nb0013dx Battery Replacement: stap 10, afbeelding 2 van 2
    • Gently lift the battery by holding the top.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 11
Altijd: 187
