Inleiding
This guide will show you how to replace the HP Chromebook 11A G8 EE’s Wi-Fi card. The Wi-Fi card is a built in component of your laptop. The Wi-Fi card allows allows your laptop to connect to wireless internet. The Wi-Fi card of your device may need to be replaced if your device is failing to connect to wireless internet.
Wat je nodig hebt
On the bottom of the laptop, remove four 7 mm screw using a Phillips #1 screwdriver.
Using the Phillips #1 screwdriver, remove the two remaining 8 mm screws by the hinges.
