Inleiding
This guide will show you how to replace the HP Chromebook 11A G8 EE’s touchpad. The touchpad allows you to control the cursor of your Chromebook. If your touchpad is not responding it may need to be replaced.
Prior to beginning the repair, be sure to power off your Chromebook and disconnect from the charging cord.
Wat je nodig hebt
On the bottom of the laptop, remove four 7 mm screw using a Phillips #1 screwdriver.
Using the Phillips #1 screwdriver, remove the two remaining 8 mm screws by the hinges.
