Ga door naar hoofdinhoud
HP Chromebook 11A G8 EE Keyboard Assembly Replacement
Wat je nodig hebt
  1. HP Chromebook 11A G8 EE Keyboard Assembly Replacement, Keyboard Assembly: stap 1, afbeelding 1 van 2 HP Chromebook 11A G8 EE Keyboard Assembly Replacement, Keyboard Assembly: stap 1, afbeelding 2 van 2
    • On the bottom of the laptop, remove four 7 mm screw using a Phillips #1 screwdriver.
    • Using the Phillips #1 screwdriver, remove the two remaining 8 mm screws by the hinges.
  2. HP Chromebook 11A G8 EE Keyboard Assembly Replacement: stap 2, afbeelding 1 van 3 HP Chromebook 11A G8 EE Keyboard Assembly Replacement: stap 2, afbeelding 2 van 3 HP Chromebook 11A G8 EE Keyboard Assembly Replacement: stap 2, afbeelding 3 van 3
    • Flip the laptop over and open up the display.
    • Using the iFixit opening tool, carefully separate the palm rest from the bottom cover by working your way around the perimeter and prying it up.
    • You will hear an audible and tactile click or pop letting you know that you have unclipped a portion of the palm rest from the base enclosure.
    • Lift the palm rest of the laptops towards you, away from the screen.
  3. HP Chromebook 11A G8 EE Keyboard Assembly Replacement: stap 3, afbeelding 1 van 2 HP Chromebook 11A G8 EE Keyboard Assembly Replacement: stap 3, afbeelding 2 van 2
    • Carefully, lift the keyboard ribbon lock and disconnect the keyboard ribbon from the motherboard.
    • Disconnect the touchpad ribbon from the motherboard, and remove top cover.
    • Remove the keyboard.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Ella Portwood
684 Reputatie
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 48
Altijd: 2,440
