Ga door naar hoofdinhoud
HP Chromebook 11-v011dx Speaker Replacement
Wat je nodig hebt
  1. HP Chromebook 11-v011dx Speaker  Replacement, Key Board: stap 1, afbeelding 1 van 3 HP Chromebook 11-v011dx Speaker  Replacement, Key Board: stap 1, afbeelding 2 van 3 HP Chromebook 11-v011dx Speaker  Replacement, Key Board: stap 1, afbeelding 3 van 3
    • Wedge the spudger between one of the black rubber caps on each of the four corners on the bottom of the HP Chromebook 11-v011dx.
    • Lift up the black rubber cap until it is completely removed.
    • Repeat this until all four of the black rubber caps are removed.
  2. HP Chromebook 11-v011dx Speaker  Replacement: stap 2, afbeelding 1 van 2 HP Chromebook 11-v011dx Speaker  Replacement: stap 2, afbeelding 2 van 2
    • Locate the two smaller black rubber caps on the top corners of the HP ChromeBook 11-v011dx. Wedge the spudger between one of them.
    • Lift up the small black rubber cap until it is completely off.
    • Repeat this step one more time to remove the other small black rubber cap on the other side.
  3. HP Chromebook 11-v011dx Speaker  Replacement: stap 3, afbeelding 1 van 2 HP Chromebook 11-v011dx Speaker  Replacement: stap 3, afbeelding 2 van 2
    • Locate the eleven screws on the bottom the HP ChromeBook. Six are located under the larger black rubber caps and the others are in different locations.
    • Use a Phillips #0 screwdriver to remove eleven 1.3mm screws.
  4. HP Chromebook 11-v011dx Speaker  Replacement: stap 4, afbeelding 1 van 3 HP Chromebook 11-v011dx Speaker  Replacement: stap 4, afbeelding 2 van 3 HP Chromebook 11-v011dx Speaker  Replacement: stap 4, afbeelding 3 van 3
    • Make sure to do steps 1-3 or it will be impossible to lift up the key board and you may also do damage to the hardware.
    • Wedge the spudger between the key board and the bottom panel, carefully go around the keyboards edges gently.
    • Lift the spudger a little in the front of the keyboard until the key board lifts up.
    • With your hands, slowly and carefully lift the key board up.
  5. HP Chromebook 11-v011dx Speaker  Replacement: stap 5, afbeelding 1 van 1
    • Locate the black tab that holds a wire in place that keeps the keyboard connected to the mother board.
    • Slowly unplug this wire that connects to the key board.
  6. HP Chromebook 11-v011dx Speaker  Replacement, Battery: stap 6, afbeelding 1 van 2 HP Chromebook 11-v011dx Speaker  Replacement, Battery: stap 6, afbeelding 2 van 2
    • Remove three of the 1.3mm screws that keep the battery in place with a Phillips #0 screwdriver.
  7. HP Chromebook 11-v011dx Speaker  Replacement: stap 7, afbeelding 1 van 1
    • Make sure to hold the white tab portion of the plug and not the wire itself. If you unplug it by holding the wires, you may rip out the wires.
    • Slowly unplug the wire that connects the battery to the motherboard with your hands.
  8. HP Chromebook 11-v011dx Speaker  Replacement: stap 8, afbeelding 1 van 1
    • There is a thick black wire strip that is going across the battery for a different part of the HP ChromeBook 11-v011dx. Be mindful when removing the motherboard so you do not damage this strip.
    • Remove the battery carefully using your hands.
  9. HP Chromebook 11-v011dx Speaker  Replacement, Speaker: stap 9, afbeelding 1 van 2 HP Chromebook 11-v011dx Speaker  Replacement, Speaker: stap 9, afbeelding 2 van 2
    • Use a Phillips #0 screwdriver to remove the one 1.3mm screw that connects the speakers and the motherboard together.
  10. HP Chromebook 11-v011dx Speaker  Replacement: stap 10, afbeelding 1 van 1
    • Make sure to hold the white part of the plug and not the wire. If unplugged by holding the wires, it can rip out wires.
    • Slowly and cautiously unplug the wire that connects the speakers to the motherboard with your hands.
  11. HP Chromebook 11-v011dx Speaker  Replacement: stap 11, afbeelding 1 van 2 HP Chromebook 11-v011dx Speaker  Replacement: stap 11, afbeelding 2 van 2
    • Be careful with the wire between both end of the speakers. It's between metal parts and can get caught.
    • Slowly remove both ends of the speakers with your hands.
Conclusie
Kyle DeMello
542 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team S4-G2, Julie Fall 2017 Lid van UMass Dartmouth, Team S4-G2, Julie Fall 2017
UMASSD-JULIE-F17S4G2
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 107
