Inleiding
Screens can become damaged in many ways. This guide will help replace the screen.
Wat je nodig hebt
Wedge the spudger between one of the black rubber caps on each of the four corners on the bottom of the HP Chromebook 11-v011dx.
Lift up the black rubber cap until it is completely removed.
Repeat this until all four of the black rubber caps are removed.
Locate the two smaller black rubber caps on the top corners of the HP ChromeBook 11-v011dx. Wedge the spudger between one of them.
Lift up the small black rubber cap until it is completely off.
Repeat this step one more time to remove the other small black rubber cap on the other side.
Use a Phillips #0 screwdriver to remove the 1.3 mm screw that holds the wireless card.
Één andere persoon heeft deze handleiding voltooid.
