Ga door naar hoofdinhoud
HP Chromebook 11-v011dx Key Board Replacement
Wat je nodig hebt
  1. HP Chromebook 11-v011dx Key Board  Replacement, Key Board: stap 1, afbeelding 1 van 3 HP Chromebook 11-v011dx Key Board  Replacement, Key Board: stap 1, afbeelding 2 van 3 HP Chromebook 11-v011dx Key Board  Replacement, Key Board: stap 1, afbeelding 3 van 3
    • Wedge the spudger between one of the black rubber caps on each of the four corners on the bottom of the HP Chromebook 11-v011dx.
    • Lift up the black rubber cap until it is completely removed.
    • Repeat this until all four of the black rubber caps are removed.
  2. HP Chromebook 11-v011dx Key Board  Replacement: stap 2, afbeelding 1 van 2 HP Chromebook 11-v011dx Key Board  Replacement: stap 2, afbeelding 2 van 2
    • Locate the two smaller black rubber caps on the top corners of the HP ChromeBook 11-v011dx. Wedge the spudger between one of them.
    • Lift up the small black rubber cap until it is completely off.
    • Repeat this step one more time to remove the other small black rubber cap on the other side.
  3. HP Chromebook 11-v011dx Key Board  Replacement: stap 3, afbeelding 1 van 2 HP Chromebook 11-v011dx Key Board  Replacement: stap 3, afbeelding 2 van 2
    • Locate the eleven screws on the bottom the HP ChromeBook. Six are located under the larger black rubber caps and the others are in different locations.
    • Use a Phillips #0 screwdriver to remove eleven 1.3mm screws.
  4. HP Chromebook 11-v011dx Key Board  Replacement: stap 4, afbeelding 1 van 3 HP Chromebook 11-v011dx Key Board  Replacement: stap 4, afbeelding 2 van 3 HP Chromebook 11-v011dx Key Board  Replacement: stap 4, afbeelding 3 van 3
    • Make sure to do steps 1-3 or it will be impossible to lift up the key board and you may also do damage to the hardware.
    • Wedge the spudger between the key board and the bottom panel, carefully go around the keyboards edges gently.
    • Lift the spudger a little in the front of the keyboard until the key board lifts up.
    • With your hands, slowly and carefully lift the key board up.
  5. HP Chromebook 11-v011dx Key Board  Replacement: stap 5, afbeelding 1 van 1
    • Locate the black tab that holds a wire in place that keeps the keyboard connected to the mother board.
    • Slowly unplug this wire that connects to the key board.
Conclusie
Kyle DeMello
542 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team S4-G2, Julie Fall 2017 Lid van UMass Dartmouth, Team S4-G2, Julie Fall 2017
UMASSD-JULIE-F17S4G2
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 258
