Ga door naar hoofdinhoud
HP Chromebook 11-v002dx Motherboard Replacement
Wat je nodig hebt
  1. HP Chromebook 11-v002dx Motherboard Replacement, Keyboard: stap 1, afbeelding 1 van 2 HP Chromebook 11-v002dx Motherboard Replacement, Keyboard: stap 1, afbeelding 2 van 2
    • Working with your device plugged in may result in electric shock. Be sure to power off your device and unplug it from any power source before proceeding with step one.
    • Place your laptop bottom up on your work space.
    • Use a Phillips #0 screwdriver to remove the eleven 0.2 mm screws, including the six from underneath the adhesives.
  2. HP Chromebook 11-v002dx Motherboard Replacement: stap 2, afbeelding 1 van 3 HP Chromebook 11-v002dx Motherboard Replacement: stap 2, afbeelding 2 van 3 HP Chromebook 11-v002dx Motherboard Replacement: stap 2, afbeelding 3 van 3
    • Using a sharp tool, remove the six adhesives from the bottom of your laptop to expose the screwheads underneath. Two of the pads are small and four are larger.
  3. HP Chromebook 11-v002dx Motherboard Replacement: stap 3, afbeelding 1 van 2 HP Chromebook 11-v002dx Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Use a plastic opening tool to loosen the keyboard face from the device.
    • Start prying at one end of the laptop and slowly work your way around so as not to break the keyboard.
  4. HP Chromebook 11-v002dx Motherboard Replacement: stap 4, afbeelding 1 van 2 HP Chromebook 11-v002dx Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Lift the keyboard so that the inner workings of the laptop are exposed.
    • Gently pull each of the two ribbons connecting the keyboard to the device so that neither ribbon is still connected to the device, only to the keyboard.
  5. HP Chromebook 11-v002dx Motherboard Replacement, Motherboard: stap 5, afbeelding 1 van 2 HP Chromebook 11-v002dx Motherboard Replacement, Motherboard: stap 5, afbeelding 2 van 2
    • Pinch the thin black bar which holds the right side of the black ribbon down, and flip it up.
    • Gently pull the ribbon out of the black holder on its right, then out of the left side as well.
  6. HP Chromebook 11-v002dx Motherboard Replacement: stap 6, afbeelding 1 van 3 HP Chromebook 11-v002dx Motherboard Replacement: stap 6, afbeelding 2 van 3 HP Chromebook 11-v002dx Motherboard Replacement: stap 6, afbeelding 3 van 3
    • Squeeze the three white connectors on their sides to disconnect them.
    • Use your Phillips #0 screwdriver to unscrew the five 0.2 mm screws from the motherboard.
  7. HP Chromebook 11-v002dx Motherboard Replacement: stap 7, afbeelding 1 van 2 HP Chromebook 11-v002dx Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Flip up the two clear tabs and the blue tab at the top of the motherboard.
    • Use your tweezers to lift each tab away so their connected components are no longer attached to the motherboard.
  8. HP Chromebook 11-v002dx Motherboard Replacement: stap 8, afbeelding 1 van 2 HP Chromebook 11-v002dx Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Use your tweezers to pull the two metal pieces connecting the two wires to the top of the green wifi card above the motherboard.
    • Use your Phillips head screwdriver to unscrew the 0.2 mm screw from the wifi card.
  9. HP Chromebook 11-v002dx Motherboard Replacement: stap 9, afbeelding 1 van 2 HP Chromebook 11-v002dx Motherboard Replacement: stap 9, afbeelding 2 van 2
    • Grab the motherboard on its bottom right corner and pull it out of the laptop.
    • Ensure all connection points and motherboard are free of dust and any stickiness, then if necessary replace entire motherboard.
Conclusie
Abby Zilvitis
448 Reputatie
4 handleidingen geschreven
Cal Poly, Team S14-G1, Banghart Spring 2017 Lid van Cal Poly, Team S14-G1, Banghart Spring 2017
CPSU-BANGHART-S17S14G1
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 474
