Ga door naar hoofdinhoud
HP Chromebook 11-2210nr Speakers Replacement
Wat je nodig hebt
  1. HP Chromebook 11-2210nr Speakers Replacement, Speakers: stap 1, afbeelding 1 van 2 HP Chromebook 11-2210nr Speakers Replacement, Speakers: stap 1, afbeelding 2 van 2
    • Position your closed laptop face down to remove the 9 visible 6mm screws using the Phillips #1 screwdriver.
  2. HP Chromebook 11-2210nr Speakers Replacement: stap 2, afbeelding 1 van 3 HP Chromebook 11-2210nr Speakers Replacement: stap 2, afbeelding 2 van 3 HP Chromebook 11-2210nr Speakers Replacement: stap 2, afbeelding 3 van 3
    • Using the metal spudger, remove the two rubber pads that are closer to the hinge of the laptop.
    • Remove the two additional 6mm screws located beneath the rubber pads using the Phillips #1 screwdriver.
    • The two bottom rubber pads do not contain screws, but you may check if you wish to be sure.
  3. HP Chromebook 11-2210nr Speakers Replacement: stap 3, afbeelding 1 van 3 HP Chromebook 11-2210nr Speakers Replacement: stap 3, afbeelding 2 van 3 HP Chromebook 11-2210nr Speakers Replacement: stap 3, afbeelding 3 van 3
    • Turn the Laptop over and with the metal spudger start to run it along the plastic seam to pry it off.
    • You will hear popping sounds when you are sliding the spudger along the device.
    • For an easier removal, start from the sides and work your way in to the corners.
  4. HP Chromebook 11-2210nr Speakers Replacement: stap 4, afbeelding 1 van 3 HP Chromebook 11-2210nr Speakers Replacement: stap 4, afbeelding 2 van 3 HP Chromebook 11-2210nr Speakers Replacement: stap 4, afbeelding 3 van 3
    • Carefully lift off the keyboard and gently place it towards you until the two ZIF ribbon wires become visible and place the keyboard down.
    • Locate where the two ZIF ribbon wires are connecting the keyboard to the motherboard in place by clasps.
    • This does not disconnect the keyboard from the laptop just yet.
  5. HP Chromebook 11-2210nr Speakers Replacement: stap 5, afbeelding 1 van 3 HP Chromebook 11-2210nr Speakers Replacement: stap 5, afbeelding 2 van 3 HP Chromebook 11-2210nr Speakers Replacement: stap 5, afbeelding 3 van 3
    • Using the nylon spudger, lift the plastic clasps holding the two ribbon wires up to properly disconnect the wires.
    • It is recommended to use the nylon spudger for this step. Any metal can damage your motherboard.
    • This step completely disconnects the keyboard to allow safe removal and replacement.
  6. HP Chromebook 11-2210nr Speakers Replacement: stap 6, afbeelding 1 van 2 HP Chromebook 11-2210nr Speakers Replacement: stap 6, afbeelding 2 van 2
    • Remove the six 4mm screws holding the battery in place with a Phillips #1 screwdriver.
  7. HP Chromebook 11-2210nr Speakers Replacement: stap 7, afbeelding 1 van 3 HP Chromebook 11-2210nr Speakers Replacement: stap 7, afbeelding 2 van 3 HP Chromebook 11-2210nr Speakers Replacement: stap 7, afbeelding 3 van 3
    • Carefully unplug the bundle power cable by pulling both edges towards you.
    • This successfully disconnects the battery from the laptop.
  8. HP Chromebook 11-2210nr Speakers Replacement: stap 8, afbeelding 1 van 3 HP Chromebook 11-2210nr Speakers Replacement: stap 8, afbeelding 2 van 3 HP Chromebook 11-2210nr Speakers Replacement: stap 8, afbeelding 3 van 3
    • Carefully lift the battery and safely remove it out of the laptop.
    • The battery may have an adhesive sticker attached to the bottom. If so, apply more force when lifting it up.
    • After the removal of the battery, the speakers will become accessible.
  9. HP Chromebook 11-2210nr Speakers Replacement: stap 9, afbeelding 1 van 3 HP Chromebook 11-2210nr Speakers Replacement: stap 9, afbeelding 2 van 3 HP Chromebook 11-2210nr Speakers Replacement: stap 9, afbeelding 3 van 3
    • Use the metal spudger to release the LEFT speakers from the laptop.
    • Use the metal spudger to release the RIGHT speaker from the laptop.
    • The two speakers are connected to a wire that runs along the bottom edge of the laptop and connected up to the motherboard.
  10. HP Chromebook 11-2210nr Speakers Replacement: stap 10, afbeelding 1 van 3 HP Chromebook 11-2210nr Speakers Replacement: stap 10, afbeelding 2 van 3 HP Chromebook 11-2210nr Speakers Replacement: stap 10, afbeelding 3 van 3
    • Unplug the speakers small wire bundle from the motherboard.
    • You will notice the speaker wire is pinched between a screw slot and underneath the motherboard.
  11. HP Chromebook 11-2210nr Speakers Replacement: stap 11, afbeelding 1 van 2 HP Chromebook 11-2210nr Speakers Replacement: stap 11, afbeelding 2 van 2
    • Remove the one 4mm screw located above the pinched wire.
  12. HP Chromebook 11-2210nr Speakers Replacement: stap 12, afbeelding 1 van 3 HP Chromebook 11-2210nr Speakers Replacement: stap 12, afbeelding 2 van 3 HP Chromebook 11-2210nr Speakers Replacement: stap 12, afbeelding 3 van 3
    • Using the nylon spudger, slightly pry up the motherboard to release the pinched wire.
    • This step completely disconnects the speaker from the laptop to be safely removed.
Conclusie
Gerardo Cardona
364 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 138
