Ga door naar hoofdinhoud
HP Chromebook 11-2210nr LCD Screen Replacement
Wat je nodig hebt
  1. HP Chromebook 11-2210nr LCD Screen Replacement, LCD Screen: stap 1, afbeelding 1 van 1
    • Remove adhesive tabs using fine point tweezers or a metal spudger.
    • These adhesives are typically located at the bottom left and right corners of the screen.
  2. HP Chromebook 11-2210nr LCD Screen Replacement: stap 2, afbeelding 1 van 1
    • Remove the one 3 mm screw located underneath both adhesive layers using a Phillips #0 screwdriver.
  3. HP Chromebook 11-2210nr LCD Screen Replacement: stap 3, afbeelding 1 van 2 HP Chromebook 11-2210nr LCD Screen Replacement: stap 3, afbeelding 2 van 2
    • Using a metal spudger, gently pry the front plastic frame (or bezel) off of the device by inserting the tool along the inside edge of the bezel.
    • Completely open the screen as far as possible to remove the bottom edge of the bezel from the laptop.
    • Be sure to disconnect the bezel from all the way around the screen before completely removing.
  4. HP Chromebook 11-2210nr LCD Screen Replacement: stap 4, afbeelding 1 van 2 HP Chromebook 11-2210nr LCD Screen Replacement: stap 4, afbeelding 2 van 2
    • Remove the four black 3 mm screws along the left and right sides of the LCD screen using a Phillips #0 screwdriver.
  5. HP Chromebook 11-2210nr LCD Screen Replacement: stap 5, afbeelding 1 van 1
    • After removing all screws, gently lower the LCD screen onto the keyboard.
    • The LCD screen will not be completely disconnected from the laptop just yet.
  6. HP Chromebook 11-2210nr LCD Screen Replacement: stap 6, afbeelding 1 van 2 HP Chromebook 11-2210nr LCD Screen Replacement: stap 6, afbeelding 2 van 2
    • Gently use the spudger to pry off the tape on top of the gold chip. You may also use your hands to gently remove the tape.
  7. HP Chromebook 11-2210nr LCD Screen Replacement: stap 7, afbeelding 1 van 2 HP Chromebook 11-2210nr LCD Screen Replacement: stap 7, afbeelding 2 van 2
    • Remove the display cable by gently sliding out the cable away from the LCD screen.
    • This action disconnects the LCD screen from the rest of the device, allowing it to be completely removed.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Kimberly Rodriguez
425 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 330
