Ga door naar hoofdinhoud
HP Chromebook 11 G5 DC Charging Port Replacement
Wat je nodig hebt
  1. HP Chromebook 11 G5 DC Charging Port Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • Remove four large rubber pads from the bottom of the device to reveal screws using the pointed end of a spudger.
  2. HP Chromebook 11 G5 DC Charging Port Replacement: stap 2, afbeelding 1 van 1
    • Remove two smaller rubber pads from the bottom of the device to reveal screws using the pointed end of a spudger.
  3. HP Chromebook 11 G5 DC Charging Port Replacement: stap 3, afbeelding 1 van 1
    • Remove the 4mm eleven screws using a Phillips #00 screwdriver.
  4. HP Chromebook 11 G5 DC Charging Port Replacement: stap 4, afbeelding 1 van 1
    • Flip the device upright and open the screen as far back as possible.
  5. HP Chromebook 11 G5 DC Charging Port Replacement: stap 5, afbeelding 1 van 1
    • Wedge the flat-end of a metal spudger between the base of the device and the keyboard assembly while applying downward pressure. Slide the spudger across the entirety of the gap until the two components separate.
    • There will be audible popping sounds caused by the separation of the base of the device and the keyboard assembly as you wedge them apart.
    • Do not insert the spudger into the gap deeper than necessary as it may snag on the internal components.
  6. HP Chromebook 11 G5 DC Charging Port Replacement: stap 6, afbeelding 1 van 1
    • Gently lift the keyboard assembly slightly above the base of the device.
  7. HP Chromebook 11 G5 DC Charging Port Replacement: stap 7, afbeelding 1 van 1
    • Disconnect the two ribbon cables connected to the motherboard by using the pointed end of a spudger to lift the plastic connector lids to allow the ribbon cables to be gently removed by hand.
  8. HP Chromebook 11 G5 DC Charging Port Replacement: stap 8, afbeelding 1 van 1
    • Gently remove the keyboard assembly by hand from the base of the device.
  9. HP Chromebook 11 G5 DC Charging Port Replacement, DC Charging Port: stap 9, afbeelding 1 van 1
    • Disconnect the charging port cable from the motherboard using your finger or a spudger and gently pull it off.
  10. HP Chromebook 11 G5 DC Charging Port Replacement: stap 10, afbeelding 1 van 1
    • Remove the two screws from the hinge of the device using a Phillips #00 screwdriver.
    • Carefully lift the hinge up.
  11. HP Chromebook 11 G5 DC Charging Port Replacement: stap 11, afbeelding 1 van 1
    • Carefully lift the charging port cable with the hinge up to remove the DC charging port.
  12. HP Chromebook 11 G5 DC Charging Port Replacement: stap 12, afbeelding 1 van 1
    • Carefully remove the DC charging port from the base using a spudger.
Conclusie
Salma Zitoun
385 Reputatie
2 handleidingen geschreven
2Gids Commentaar
I thought it was going to be a little bit more difficult than it was . I got it done in about 15-20 minutes. Thanks to this.
Maryann Charles - Antwoord
Do you guys sell these replacement DC Ports or know where to find them? (I work for a school, but the students keep breaking things! I need, like, 25 of these… yep, it’s that bad. Even found a literal nest of cockroaches inside one of them. I still have the picture/video of it for the morbidly curious lol.)
Aaron Yamauchi - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 35
Altijd: 1,423
