Ga door naar hoofdinhoud
HP Chromebook 11 G3 Keyboard Replacement
Wat je nodig hebt
  1. HP Chromebook 11 G3 Keyboard Replacement, Keyboard Mount: stap 1, afbeelding 1 van 2 HP Chromebook 11 G3 Keyboard Replacement, Keyboard Mount: stap 1, afbeelding 2 van 2
    • Flip the laptop upside down so that the lid lies flat on the table.
    • Remove the nine 6mm Phillips #00 screws that line the border.
  2. HP Chromebook 11 G3 Keyboard Replacement: stap 2, afbeelding 1 van 2 HP Chromebook 11 G3 Keyboard Replacement: stap 2, afbeelding 2 van 2
    • Remove the two rubber feet closest to the hinge using tweezers.
    • Remove the two 6mm Phillips #00 screws revealed under these rubber feet.
    • The rubber feet may tear while removal; preventing this can be difficult, but it won’t harm the laptop. If desired, replace these rubber feet during reassembly.
  3. HP Chromebook 11 G3 Keyboard Replacement: stap 3, afbeelding 1 van 1
    • Flip the laptop so it is in the upright position.
    • Open the lid.
    • Unsnap the keyboard mount along the border of the laptop using a plastic opening tool.
    • This may require more force than expected. Hearing loud clicks as the plastic opening tool slides along the seam is normal.
  4. HP Chromebook 11 G3 Keyboard Replacement: stap 4, afbeelding 1 van 3 HP Chromebook 11 G3 Keyboard Replacement: stap 4, afbeelding 2 van 3 HP Chromebook 11 G3 Keyboard Replacement: stap 4, afbeelding 3 van 3
    • Tilt the keyboard mount up.
    • Use a spudger to flip up the two ZIF connector retaining flaps for the ribbon cables that connect the keyboard mount to the motherboard.
    • Gently remove both ribbon cables.
  5. HP Chromebook 11 G3 Keyboard Replacement: stap 5, afbeelding 1 van 1
    • Lift the keyboard mount out of the laptop.
  6. HP Chromebook 11 G3 Keyboard Replacement, Keyboard: stap 6, afbeelding 1 van 2 HP Chromebook 11 G3 Keyboard Replacement, Keyboard: stap 6, afbeelding 2 van 2
    • Flip the keyboard mount upside-down.
    • Using tweezers, peel off the two pieces of copper tape that keep the keyboard’s metal cover attached to the keyboard mount.
  7. HP Chromebook 11 G3 Keyboard Replacement: stap 7, afbeelding 1 van 1
    • Using tweezers, pull back the three metallic-colored pieces of tape near the top left corner of the keyboard mount.
  8. HP Chromebook 11 G3 Keyboard Replacement: stap 8, afbeelding 1 van 2 HP Chromebook 11 G3 Keyboard Replacement: stap 8, afbeelding 2 van 2
    • Remove the two 4 mm Phillips #00 screws located on either side of the horizontal black fastener located directly above the touchpad.
    • Lift the horizontal black fastener.
  9. HP Chromebook 11 G3 Keyboard Replacement: stap 9, afbeelding 1 van 3 HP Chromebook 11 G3 Keyboard Replacement: stap 9, afbeelding 2 van 3 HP Chromebook 11 G3 Keyboard Replacement: stap 9, afbeelding 3 van 3
    • Use a plastic opening tool to pry the edges of the metal cover.
    • Loosen the adhesive around the perimeter of the metal cover.
    • The adhesive can be difficult to remove. Use tweezers on any troubling sections. After removing the adhesive, take off the keyboard’s metal cover.
    • If the cover doesn’t come off, repeat prying around the edges with a plastic opening tool.
    • Lift the metal cover.
    • Apply adhesive during reassembly to fasten the metal cover onto the keyboard mount.
    • If only certain keys need replacement, stop here. Instead, use tweezers to remove individual keys by loosening their four snap-on clips from the metal backing.
  10. HP Chromebook 11 G3 Keyboard Replacement: stap 10, afbeelding 1 van 2 HP Chromebook 11 G3 Keyboard Replacement: stap 10, afbeelding 2 van 2
    • Use a plastic opening tool to disconnect the keyboard from the keyboard mount by prying along the keyboard’s perimeter.
    • Lots of adhesive attaches the keyboard to the keyboard mount. Loud snapping noises and gray, circular plastic debris are common during adhesive removal.
    • After removing enough adhesive, remove the keyboard’s backing.
    • Apply adhesive during reassembly to fasten the keyboard and its metal backing onto the keyboard mount.
Conclusie
Rahul Goyal
1.369 Reputatie
10 handleidingen geschreven
Cal Poly, Team S23-G3, Livingston Spring 2017 Lid van Cal Poly, Team S23-G3, Livingston Spring 2017
CPSU-LIVINGSTON-S17S23G3
4 Leden
12 handleidingen geschreven
Één opmerking
Is it possible to get a keyboard that lights up for the HP Chromebook 11 G3? If so then how?
Vanessa Nations - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 12
Altijd: 2,065
