Ga door naar hoofdinhoud
HP Chromebook 11 G3 Display Assembly Replacement
Wat je nodig hebt
  1. HP Chromebook 11 G3 Display Assembly Replacement, Keyboard Mount: stap 1, afbeelding 1 van 2 HP Chromebook 11 G3 Display Assembly Replacement, Keyboard Mount: stap 1, afbeelding 2 van 2
    • Flip the laptop upside down so that the lid lies flat on the table.
    • Remove the nine 6mm Phillips #00 screws that line the border.
  2. HP Chromebook 11 G3 Display Assembly Replacement: stap 2, afbeelding 1 van 2 HP Chromebook 11 G3 Display Assembly Replacement: stap 2, afbeelding 2 van 2
    • Remove the two rubber feet closest to the hinge using tweezers.
    • Remove the two 6mm Phillips #00 screws revealed under these rubber feet.
    • The rubber feet may tear while removal; preventing this can be difficult, but it won’t harm the laptop. If desired, replace these rubber feet during reassembly.
  3. HP Chromebook 11 G3 Display Assembly Replacement: stap 3, afbeelding 1 van 1
    • Flip the laptop so it is in the upright position.
    • Open the lid.
    • Unsnap the keyboard mount along the border of the laptop using a plastic opening tool.
    • This may require more force than expected. Hearing loud clicks as the plastic opening tool slides along the seam is normal.
  4. HP Chromebook 11 G3 Display Assembly Replacement: stap 4, afbeelding 1 van 3 HP Chromebook 11 G3 Display Assembly Replacement: stap 4, afbeelding 2 van 3 HP Chromebook 11 G3 Display Assembly Replacement: stap 4, afbeelding 3 van 3
    • Tilt the keyboard mount up.
    • Use a spudger to flip up the two ZIF connector retaining flaps for the ribbon cables that connect the keyboard mount to the motherboard.
    • Gently remove both ribbon cables.
  5. HP Chromebook 11 G3 Display Assembly Replacement: stap 5, afbeelding 1 van 1
    • Lift the keyboard mount out of the laptop.
  6. HP Chromebook 11 G3 Display Assembly Replacement, Display Assembly: stap 6, afbeelding 1 van 1
    • Gently tug on the black and white wires connected to the Wi-Fi module to disconnect them.
  7. HP Chromebook 11 G3 Display Assembly Replacement: stap 7, afbeelding 1 van 2 HP Chromebook 11 G3 Display Assembly Replacement: stap 7, afbeelding 2 van 2
    • Using a spudger, lift the ZIF retaining flap that secures the display’s ribbon cable to the motherboard.
    • Gently pull the ribbon cable out of its socket.
  8. HP Chromebook 11 G3 Display Assembly Replacement: stap 8, afbeelding 1 van 1
    • Free the wire from the casing.
  9. HP Chromebook 11 G3 Display Assembly Replacement: stap 9, afbeelding 1 van 1
    • Remove the two 6mm Phillips #00 screws located near the upper left and right corners of the hinge mounts.
    • Hold the lid so that it is folded slightly inwards while removing the screws so that the lid doesn’t fall.
  10. HP Chromebook 11 G3 Display Assembly Replacement: stap 10, afbeelding 1 van 1
    • Rotate the lid to a 90-degree angle with the table.
    • Shimmy the lid out of the laptop.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Rahul Goyal
1.369 Reputatie
10 handleidingen geschreven
Cal Poly, Team S23-G3, Livingston Spring 2017 Lid van Cal Poly, Team S23-G3, Livingston Spring 2017
CPSU-LIVINGSTON-S17S23G3
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 8
Altijd: 1,472
