Ga door naar hoofdinhoud
HP Chromebook 11 G3 Battery Replacement
Wat je nodig hebt
  1. HP Chromebook 11 G3 Battery Replacement, Keyboard Mount: stap 1, afbeelding 1 van 2 HP Chromebook 11 G3 Battery Replacement, Keyboard Mount: stap 1, afbeelding 2 van 2
    • Flip the laptop upside down so that the lid lies flat on the table.
    • Remove the nine 6mm Phillips #00 screws that line the border.
  2. HP Chromebook 11 G3 Battery Replacement: stap 2, afbeelding 1 van 2 HP Chromebook 11 G3 Battery Replacement: stap 2, afbeelding 2 van 2
    • Remove the two rubber feet closest to the hinge using tweezers.
    • Remove the two 6mm Phillips #00 screws revealed under these rubber feet.
    • The rubber feet may tear while removal; preventing this can be difficult, but it won’t harm the laptop. If desired, replace these rubber feet during reassembly.
  3. HP Chromebook 11 G3 Battery Replacement: stap 3, afbeelding 1 van 1
    • Flip the laptop so it is in the upright position.
    • Open the lid.
    • Unsnap the keyboard mount along the border of the laptop using a plastic opening tool.
    • This may require more force than expected. Hearing loud clicks as the plastic opening tool slides along the seam is normal.
  4. HP Chromebook 11 G3 Battery Replacement: stap 4, afbeelding 1 van 3 HP Chromebook 11 G3 Battery Replacement: stap 4, afbeelding 2 van 3 HP Chromebook 11 G3 Battery Replacement: stap 4, afbeelding 3 van 3
    • Tilt the keyboard mount up.
    • Use a spudger to flip up the two ZIF connector retaining flaps for the ribbon cables that connect the keyboard mount to the motherboard.
    • Gently remove both ribbon cables.
  5. HP Chromebook 11 G3 Battery Replacement: stap 5, afbeelding 1 van 1
    • Lift the keyboard mount out of the laptop.
  6. HP Chromebook 11 G3 Battery Replacement, Battery: stap 6, afbeelding 1 van 1
    • Gently remove the battery’s rainbow-colored bundled cable from the motherboard.
  7. HP Chromebook 11 G3 Battery Replacement: stap 7, afbeelding 1 van 2 HP Chromebook 11 G3 Battery Replacement: stap 7, afbeelding 2 van 2
    • Remove the six 4 mm Phillips #00 screws located along the perimeter of the battery.
  8. HP Chromebook 11 G3 Battery Replacement: stap 8, afbeelding 1 van 1
    • Lift out the battery.
    • The laptop may tip backwards onto its lid due to uneven weight distribution.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Rahul Goyal
1.369 Reputatie
10 handleidingen geschreven
Cal Poly, Team S23-G3, Livingston Spring 2017 Lid van Cal Poly, Team S23-G3, Livingston Spring 2017
CPSU-LIVINGSTON-S17S23G3
4 Leden
12 handleidingen geschreven
Één opmerking
Can the HP Chromebook 11 G3 be operated from the power adapter after the battery has been removed?
Andrew Logan - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 28
Altijd: 3,708
