Ga door naar hoofdinhoud
HP Beats Special Edition 15-p390nr Motherboard Replacement
Wat je nodig hebt
  1. HP Beats Special Edition 15-p390nr Motherboard Replacement, Keyboard: stap 1, afbeelding 1 van 2 HP Beats Special Edition 15-p390nr Motherboard Replacement, Keyboard: stap 1, afbeelding 2 van 2
    • Turn computer off before starting.
    • Turn computer over and begin removing noticeable 8mm screws with a Phillips #0 screwdriver.
  2. HP Beats Special Edition 15-p390nr Motherboard Replacement: stap 2, afbeelding 1 van 2 HP Beats Special Edition 15-p390nr Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Some screws may be hidden under a screw cover.
    • Simply use a metal spudger to pop off the screw cover to unveil the hidden 8mm screw.
    • Screw cover may fly when removing.
  3. HP Beats Special Edition 15-p390nr Motherboard Replacement: stap 3, afbeelding 1 van 2 HP Beats Special Edition 15-p390nr Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Once screws are removed you may now remove the optical drive.
    • Remove the hidden 3mm screw in the optical drive port.
  4. HP Beats Special Edition 15-p390nr Motherboard Replacement: stap 4, afbeelding 1 van 2 HP Beats Special Edition 15-p390nr Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Remove the rubberized feet located on the left and right shoulder of the computer to uncover hidden 8mm screws.
    • Popping noises are normal.
    • The shoulder caps are removable. Underneath there are 2 additional screws.
  5. HP Beats Special Edition 15-p390nr Motherboard Replacement: stap 5, afbeelding 1 van 2 HP Beats Special Edition 15-p390nr Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Flip computer over and wedge metal spudger along the computer to pop off keyboard panel
  6. HP Beats Special Edition 15-p390nr Motherboard Replacement: stap 6, afbeelding 1 van 2 HP Beats Special Edition 15-p390nr Motherboard Replacement: stap 6, afbeelding 2 van 2
    • Unclip wires connected to the motherboard and remove keyboard from the device.
    • 17 screws should be removed up to this point.
  7. HP Beats Special Edition 15-p390nr Motherboard Replacement, Motherboard: stap 7, afbeelding 1 van 1
    • Remove screws from the motherboard.
    • 11 screws should be removed from the motherboard
  8. HP Beats Special Edition 15-p390nr Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Unclamp wire strips from motherboard.
  9. HP Beats Special Edition 15-p390nr Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Detach by lifting the motherboard up and flip the motherboard over.
  10. HP Beats Special Edition 15-p390nr Motherboard Replacement: stap 10, afbeelding 1 van 1
    • Unclip wifi card for further procedures
Conclusie
Één andere persoon heeft deze handleiding voltooid.
4 opmerkingen
Please where can i buy the motherboard ?
Nelson - Antwoord
Please, where can i buy a new motherboard for this laptop ? Thank you
Nelson - Antwoord
What does it mean if it beeps twice and doesn’t turn on? I replaced the cmos battery and thought that would fix that beeping sound.
Landon Elliott - Antwoord
You may want yo start with reseating your ram or replacing it
Juan Lopez -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 28
Altijd: 2,613
