Ga door naar hoofdinhoud
HP Beats Special Edition 15-p390nr Keyboard Replacement
Wat je nodig hebt
  1. HP Beats Special Edition 15-p390nr Keyboard Replacement, Keyboard: stap 1, afbeelding 1 van 2 HP Beats Special Edition 15-p390nr Keyboard Replacement, Keyboard: stap 1, afbeelding 2 van 2
    • Turn computer off before starting.
    • Turn computer over and begin removing noticeable 8mm screws with a Phillips #0 screwdriver.
  2. HP Beats Special Edition 15-p390nr Keyboard Replacement: stap 2, afbeelding 1 van 2 HP Beats Special Edition 15-p390nr Keyboard Replacement: stap 2, afbeelding 2 van 2
    • Some screws may be hidden under a screw cover.
    • Simply use a metal spudger to pop off the screw cover to unveil the hidden 8mm screw.
    • Screw cover may fly when removing.
  3. HP Beats Special Edition 15-p390nr Keyboard Replacement: stap 3, afbeelding 1 van 2 HP Beats Special Edition 15-p390nr Keyboard Replacement: stap 3, afbeelding 2 van 2
    • Once screws are removed you may now remove the optical drive.
    • Remove the hidden 3mm screw in the optical drive port.
  4. HP Beats Special Edition 15-p390nr Keyboard Replacement: stap 4, afbeelding 1 van 2 HP Beats Special Edition 15-p390nr Keyboard Replacement: stap 4, afbeelding 2 van 2
    • Remove the rubberized feet located on the left and right shoulder of the computer to uncover hidden 8mm screws.
    • Popping noises are normal.
    • The shoulder caps are removable. Underneath there are 2 additional screws.
  5. HP Beats Special Edition 15-p390nr Keyboard Replacement: stap 5, afbeelding 1 van 2 HP Beats Special Edition 15-p390nr Keyboard Replacement: stap 5, afbeelding 2 van 2
    • Flip computer over and wedge metal spudger along the computer to pop off keyboard panel
  6. HP Beats Special Edition 15-p390nr Keyboard Replacement: stap 6, afbeelding 1 van 2 HP Beats Special Edition 15-p390nr Keyboard Replacement: stap 6, afbeelding 2 van 2
    • Unclip wires connected to the motherboard and remove keyboard from the device.
    • 17 screws should be removed up to this point.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Één opmerking
Can you add if we can take trackpad off the keyboard
Paul Schupbach - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 23
Altijd: 2,784
