Inleiding
This guide will help you to replace your broken speaker step by step. Be very careful when you remove your speaker, since using excessive force may cause damage.
Wat je nodig hebt
Using the T5 Torx Screwdriver, remove the T5x3mm screws located in all 4 corners.
Use tweezers to push out the speaker connector.
Bijna klaar!
Conclusie
