Inleiding
If the device buttons are unresponsive then it may be necessary to replace them. The most difficult step will be removing the back cover, it is important to make sure you have all tools required and follow the instructions precisely.
Wat je nodig hebt
Using the T5 Torx Screwdriver, remove the T5x3mm screws located in all 4 corners.
Bijna klaar!
Conclusie
