Ga door naar hoofdinhoud
HP 7 Plus 1302 Motherboard Replacement
Wat je nodig hebt
  1. HP 7 Plus 1302 Motherboard Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Using the T5 Torx Screwdriver, remove the T5x3mm screws located in all 4 corners.
    • Device should be turned off and unplugged before starting the replacements.
  2. HP 7 Plus 1302 Motherboard Replacement: stap 2, afbeelding 1 van 2 HP 7 Plus 1302 Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Use the plastic opening tool to push in between the front and the back of the tablet.
    • Slide the plastic opening tool around all 4 sides of the tablet to separate the back cover.
    • Be careful when you are trying to remove the back as it can damage the screen if you force it too much.
  3. HP 7 Plus 1302 Motherboard Replacement: stap 3, afbeelding 1 van 2 HP 7 Plus 1302 Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Continue sliding the plastic opening tool around the tablet until all 4 sides are separated from each other.
    • Remove the back cover.
  4. HP 7 Plus 1302 Motherboard Replacement, Battery: stap 4, afbeelding 1 van 2 HP 7 Plus 1302 Motherboard Replacement, Battery: stap 4, afbeelding 2 van 2
    • Push out the battery connector using the spudger.
    • Swing the battery connector clear of the connector socket.
  5. HP 7 Plus 1302 Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Lift the battery from the device.
  6. HP 7 Plus 1302 Motherboard Replacement, Motherboard: stap 6, afbeelding 1 van 2 HP 7 Plus 1302 Motherboard Replacement, Motherboard: stap 6, afbeelding 2 van 2
    • Pry the connector that attaches the front and back camera with a metal spudger.
  7. HP 7 Plus 1302 Motherboard Replacement: stap 7, afbeelding 1 van 2 HP 7 Plus 1302 Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Pull the camera from the connectors.
  8. HP 7 Plus 1302 Motherboard Replacement: stap 8, afbeelding 1 van 2 HP 7 Plus 1302 Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Identify the three T5x1mm screws and remove them with a Phillips #000
  9. HP 7 Plus 1302 Motherboard Replacement: stap 9, afbeelding 1 van 2 HP 7 Plus 1302 Motherboard Replacement: stap 9, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Unplug the connector with the tweezers.
    • Remove the tape.
  10. HP 7 Plus 1302 Motherboard Replacement: stap 10, afbeelding 1 van 2 HP 7 Plus 1302 Motherboard Replacement: stap 10, afbeelding 2 van 2
    • Flip the ZIF connector with the metal spudger.
    • Pull the ribbon connector out.
  11. HP 7 Plus 1302 Motherboard Replacement: stap 11, afbeelding 1 van 3 HP 7 Plus 1302 Motherboard Replacement: stap 11, afbeelding 2 van 3 HP 7 Plus 1302 Motherboard Replacement: stap 11, afbeelding 3 van 3
    • Pull the orange tape with the tweezers.
    • Flip the ZIF connector with the spudger.
    • Pull the ribbon connector with the tweezers.
  12. HP 7 Plus 1302 Motherboard Replacement: stap 12, afbeelding 1 van 1
    • Remove the gray tape below the ribbon connector.
  13. HP 7 Plus 1302 Motherboard Replacement: stap 13, afbeelding 1 van 2 HP 7 Plus 1302 Motherboard Replacement: stap 13, afbeelding 2 van 2
    • Flip the ZIF connector.
    • Pull the ribbon connector out with the tweezers.
  14. HP 7 Plus 1302 Motherboard Replacement: stap 14, afbeelding 1 van 2 HP 7 Plus 1302 Motherboard Replacement: stap 14, afbeelding 2 van 2
    • Pull the circuit board off.
Conclusie
Damaris Torres-Crespo
204 Reputatie
2 handleidingen geschreven
IUPUI, Team 1-4, Baechle Spring 2017 Lid van IUPUI, Team 1-4, Baechle Spring 2017
IUPUI-BAECHLE-S17S1G4
4 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 178
