Ga door naar hoofdinhoud
HP 7 Plus 1302 Back Cover Replacement
Wat je nodig hebt
  1. HP 7 Plus 1302 Back Cover Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Using the T5 Torx Screwdriver, remove the T5x3mm screws located in all 4 corners.
    • Device should be turned off and unplugged before starting the replacements.
  2. HP 7 Plus 1302 Back Cover Replacement: stap 2, afbeelding 1 van 2 HP 7 Plus 1302 Back Cover Replacement: stap 2, afbeelding 2 van 2
    • Use the plastic opening tool to push in between the front and the back of the tablet.
    • Slide the plastic opening tool around all 4 sides of the tablet to separate the back cover.
    • Be careful when you are trying to remove the back as it can damage the screen if you force it too much.
  3. HP 7 Plus 1302 Back Cover Replacement: stap 3, afbeelding 1 van 2 HP 7 Plus 1302 Back Cover Replacement: stap 3, afbeelding 2 van 2
    • Continue sliding the plastic opening tool around the tablet until all 4 sides are separated from each other.
    • Remove the back cover.
Conclusie
Marquies
245 Reputatie
1 Handleiding geschreven
IUPUI, Team 1-2, Renguette SU 2015 Lid van IUPUI, Team 1-2, Renguette SU 2015
IUPUI-RENGUETTE-SU15S1G2
5 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 1,046
