Ga door naar hoofdinhoud
HP 7 1800 Speaker Replacement
Wat je nodig hebt
  1. HP 7 1800 Speaker Replacement, Remove the back panel: stap 1, afbeelding 1 van 2 HP 7 1800 Speaker Replacement, Remove the back panel: stap 1, afbeelding 2 van 2
    • Carefully insert a Spudger into one of the corners of the tablet.
    • Slide the Spudger along the edge popping the tabs out along the way.
    • Be careful not to break the tabs.
  2. HP 7 1800 Speaker Replacement, Remove the battery: stap 2, afbeelding 1 van 3 HP 7 1800 Speaker Replacement, Remove the battery: stap 2, afbeelding 2 van 3 HP 7 1800 Speaker Replacement, Remove the battery: stap 2, afbeelding 3 van 3
    • Slide the Spudger under the battery to lift it off the adhesive.
    • Gently pull the cable connection from the motherboard using tweezers.
  3. HP 7 1800 Speaker Replacement, Desolder the speaker wires: stap 3, afbeelding 1 van 1
    • Desolder the two leads of the speaker wire that are connected to the motherboard.
  4. HP 7 1800 Speaker Replacement, Remove the speaker: stap 4, afbeelding 1 van 1
    • Using tweezers, gently pull the speaker off of the metal plate.
    • The speaker is held onto the metal plate with light adhesive. It will require a little force to peel off.
Conclusie
TMD
765 Reputatie
5 handleidingen geschreven
USF Tampa, Team 4-1, Brown Winter 2015 Lid van USF Tampa, Team 4-1, Brown Winter 2015
USFT-BROWN-W15S4G1
4 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 203
