Ga door naar hoofdinhoud
HP 7 1800 Motherboard Replacement
Wat je nodig hebt
  1. HP 7 1800 Motherboard Replacement, Remove the back panel: stap 1, afbeelding 1 van 2 HP 7 1800 Motherboard Replacement, Remove the back panel: stap 1, afbeelding 2 van 2
    • Carefully insert a Spudger into one of the corners of the tablet.
    • Slide the Spudger along the edge popping the tabs out along the way.
    • Be careful not to break the tabs.
  2. HP 7 1800 Motherboard Replacement, Remove the battery: stap 2, afbeelding 1 van 3 HP 7 1800 Motherboard Replacement, Remove the battery: stap 2, afbeelding 2 van 3 HP 7 1800 Motherboard Replacement, Remove the battery: stap 2, afbeelding 3 van 3
    • Slide the Spudger under the battery to lift it off the adhesive.
    • Gently pull the cable connection from the motherboard using tweezers.
  3. HP 7 1800 Motherboard Replacement, Remove the large ribbon cable: stap 3, afbeelding 1 van 2 HP 7 1800 Motherboard Replacement, Remove the large ribbon cable: stap 3, afbeelding 2 van 2
    • Remove the larger ribbon cable by gently flipping the beige latch and pulling it out with tweezers.
  4. HP 7 1800 Motherboard Replacement, Remove the smaller ribbon cable: stap 4, afbeelding 1 van 2 HP 7 1800 Motherboard Replacement, Remove the smaller ribbon cable: stap 4, afbeelding 2 van 2
    • Remove the smaller ribbon cable by gently flipping the black latch and pulling it out with tweezers.
  5. HP 7 1800 Motherboard Replacement, Unscrew the 7 silver screws from the logic board: stap 5, afbeelding 1 van 1
    • Remove the following 7 screws:
    • Six 4.17mm Phillips #00 around the motherboard.
    • One 2.67mm Phillips #00 next to the front facing camera.
    • The 2.67mm screw circled in yellow is notably shorter than the other 6 screws circled in red.
  6. HP 7 1800 Motherboard Replacement, Unplug the front facing camera from the logic board: stap 6, afbeelding 1 van 1
    • Gently pry the front facing camera plug up and off of the motherboard.
  7. HP 7 1800 Motherboard Replacement, Remove the logic board: stap 7, afbeelding 1 van 1
    • Carefully lift the motherboard directly up.
Conclusie
TMD
765 Reputatie
5 handleidingen geschreven
USF Tampa, Team 4-1, Brown Winter 2015 Lid van USF Tampa, Team 4-1, Brown Winter 2015
USFT-BROWN-W15S4G1
4 Leden
14 handleidingen geschreven
Één opmerking
After replacing the motherboard, will is act as a brand new tablet upon next boot? Will the OS and everything already be installed? Or is the main memory module elsewhere in the tablet?
jakehittinger - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 925
